What do you mean I am starting with the wrong system? I am starting with this controller as it is BUILT IN and either way I am replacing it with my teammate's DIY control switches. So you recommend me getting this R NET System for steer correction? Is getting this system a must?
Not sure what you mean by "built in". Its a ONE PART system. Its JUST the joystick pod. If you unplug that joystick and remove its two mounting screws then its no longer built in! The whole system is in your hand. So when you say you are replacing it with yours, then theres nothing left! Just batteries and motors. So replacing with yours makes no sense!
The problem with it is that:
1. Its all built into the one component. There is just one board. Theres no seperate power module anywhere.
2. Its super low powered. So much so that it will not likely be able to climb a threshold, or turn in place reliably without the user correcting it with manual control corrections. As such you need a better more powerful system for reliable control.
3. It got zero flexibility. No inputs, outputs or any advanced control programming that would allow use of your switches properly.
The R-Net system is designed to have many modules and advanced programming to make use of switches to drive etc. And its got enough power, programability to configure your switches, gyros and encoders etc to make driving with switches work properly. Inc latched control, timers, menu control, etc.
So it depends. Are you doing this to make a proper powerchair for the benefit of the user? In which case you really need a different chair AND a different control system such as the R-Net system. Or at very least fit an r-net control system.
Or are you just messing around to try and complete a student project to pass some exam and or learn stuff? In which case carry on as you are and you will learn all the things that you dont know now. And then you will understand why I say these things. Because doing what you are doing with that cheap basic system will never be useful. It might also be dangerous. You need many fail safe systems in place to prevent a fault or a user driving under a bus or breaking legs.
The difference between us is that I have 60 years of doing this stuff. And a vast store of learned solutions, know a lot of things that you dont already! Because I made all the best mistakes several times over before you were born! You have no experience to call on.
So what you do depends on the real purpose. To help an end user or to learn from a project?
