I-Pad charging from wheelchair batteries
Postby mwig » 10 Apr 2013, 20:55
I just regestered today, have found some very interesting reading. My son has a new M-400 and we are asking what is the best way to hook up an I-pad charger to the chair. I have tried wiring in a 12v marine plug to one battery. It work great for about six weeks, then batteries did not want to hold charge for a full day. I am sure someone has solved this problem. Please help.
Mwig
mwig
Re: I-Pad charging from wheelchair batteries
Postby Burgerman » 10 Apr 2013, 21:38
There are many ways.
But you cant ever take power from just one battery. Not even a tiny amount. Because on subsequent recharge the charger sees BOTH in series. So it charges until it sees the correct voltage for a pair, which is 28.2 or 28.4 volts. But if one is lower than the other then one battery gets UNDERCHARGED (and sulphated plates result) and the other gets OVERCHARGED (causes electrolyte loss, voids in the Gel on gel batteries, as well as Grid Corrosion) All very bad.
You can get 24v (nominal) from the charge port and take out power there. But you need a thing called an inverter. See here for eg: http://www.evassemble.com/index.php?mai ... rhtdl7fup4
These are efficient. Takes 24v and gives you your 12v with very little waste. Connect via charge port or direct to both batteries in series. The 36v input one is the best option.
Postby ex-Gooserider » 11 Apr 2013, 06:39
You can also get DC-DC or "buck" converter boards on E-bay (among other places) for very short money, especially if you don't need a lot of power... You can either get one that steps down to 12v so that you can use your existing car charger, or possibly find one that can step down to the power needed by the I-Bad and hook it up directly - which is going to be slightly more efficient....
However, as stated, you do NOT want to tap off just one battery, as that is a quick way to ruin a set of batteries, unless you also set up to do regular "balancing" charges, where you charge both batteries at 12V in parallel.
Postby Burgerman » 11 Apr 2013, 11:16
I-Bad
I WANT one! Sound cool! :D
Postby sheureka » 11 Apr 2013, 15:56
I just use one of these - http://www.amazon.com/Lightning-Thunder ... ords=anker - works for both my phone and my tablet.
sheureka
Postby Burgerman » 11 Apr 2013, 17:49
Postby ex-Gooserider » 12 Apr 2013, 05:00
Just as a FWIW, I was looking on E-bay last night, and they had all sorts of options for buck converters that would step anything from about 40VDC down to lower voltages Cost was variable depending on the vendor but was generally under USD $10.00 w/ shipping...
There were a few with USB jacks built in, but most only were rated at 7-22 volts in...
This was the only one rated for 24V in, and it would need some kind of case, but it's a nice option...
http://www.ebay.com/itm/KIS3R33S-DC-DC- ... 3f22e84d54
Postby Burgerman » 12 Apr 2013, 08:44
That would work with heat shrink. But 24v may be a bit upset with 26v we get running on 2 charged batteries. So maybe a couple of 5 amp diodes in series would be wise to drop the volts to 24 max.
Postby mwig » 23 Apr 2013, 21:39
Thank you all, this is very good info!
mwig
Postby Carl » 22 Oct 2013, 01:32
If you want a commercial off-the-shelf option, maybe check this out: http://www.activecontrols.com/info/info_powerbuddy.html
I would just check the output to make sure that it is enough to charge your iPad.
Cheers,
Carl
Carl
Postby Fulliautomatix » 22 Oct 2013, 08:17
I'm using this one and it's fine for a phone but although the output should be enough to charge an ipad, it won't.
Dunno why yet, I think the wiring of ipad chargers may use 2 wires in the usb connector or something.
Fulliautomatix
Postby Fulliautomatix » 22 Oct 2013, 08:18
Fulliautomatix
Postby Blade Runner » 27 Oct 2013, 17:04
XLR to USB converter from Monster Scooter Parts
http://www.monsterscooterparts.com/xlr- ... r-rec.html
Bob
Blade Runner
Postby Fulliautomatix » 28 Oct 2013, 02:21
The story is that the ipad may display 'not charging' when on a low power usb but it still charges.
http://www.digitaltrends.com/mobile/ipad-not-charging-simple-tips-for-charging-the-ipad-via-usb/
Doesn't explain 'not charging' on a 3A adapter. But I only tested it once so far.
Fulliautomatix
Postby LEEE » 29 Jun 2014, 15:52
Carl wrote:If you want a commercial off-the-shelf option, maybe check this out: http://www.activecontrols.com/info/info_powerbuddy.html
Cheers,
Carl
I bought a 'Powerbuddy' as my mobile (Samsung Galaxy S3) is extremely battery-hungry, however, the 'Powerbuddy' plug doesn't fit either my old Spectra, nor my week-old Spectra XTR2!
The idea is good, but as always, tech isn't always straight forward despite the manufacturers claims!
LEEE
Postby Burgerman » 29 Jun 2014, 16:05
Why doesn't it fit?
Same plug.
Postby LEEE » 29 Jun 2014, 16:18
Burgerman wrote:Why doesn't it fit?
Same plug.
Thanks Burgerman, but that's what my P.A. tells me (I'm very restricted & limited in movement) It may be the way the controller is close to the seat cushion!
LEEE
Postby Burgerman » 29 Jun 2014, 16:24
Fire PA. Hire BETTER one... :D
Swap for fit, young blonde that has eyes that work and enough enthusiasm to figure it out.
Postby LEEE » 29 Jun 2014, 16:31
Burgerman wrote:Fire PA. Hire BETTER one... :D
I DID hire a fit, young blonde with enthusiasm :D - shame its my eyes that are failing! LOL
LEEE
Postby Fulliautomatix » 02 Jul 2014, 10:51
I make one from BMs idea.
Good 3A output - charges anything as fast as it can go.
http://www.ebay.com.au/itm/121371915700?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Fulliautomatix
Users browsing this forum: No registered users and 13 guests
