Any review on Quantum 6000z & 6400z from pridemobility.com
Postby BILLSOTO1 » 25 Jul 2013, 19:12
Any review on Quantum 6000z & 6400z from pridemobility.com ??? IS the only fast chair I found at 8 after I used BOUNDER at 10 MPH, but I'm tired of BOUNDER. I know both QUANTUM are 8MPH, but cant find anything fast or faster. these are the specs...
Quantum 6000Z Specifications
Drive Wheels 14" Solid (Standard)
14" Pneumatic (Optional)
Caster Wheels Front: 6" Solid
Rear: 6" Solid
Maximum Speed* Up to 6.1 mph (Standard)
8.1 mph (Optional)
Ground Clearance 2.875" (caster arm)
Turning Radius 22.5" without front riggings
Overall Length 36" without front riggings
Base Width 25.875"
Synergy Seat Allowable Sizes Width1: 10" - 24"
Depth1: 10" - 24"
Power Tilt Allowable Sizes Width1: 14" - 24"
Depth1: 14" - 24"
Lift and Tilt Allowable Sizes Width1: 16" - 20"
Depth1: 16" - 20"
Pediatric Tilt Allowable Sizes Width1: 11" - 14"
Depth1: 10" - 18"
Synergy Seat Lowest Seat to Floor Height 18" - 20"2,3
Power Tilt Lowest Seat to Floor Height 17.9" - 19.9"2,3
16.6" with Super Low4
Lift and Tilt Lowest Seat to Floor Height 20"2,3
18" with Super Low4
Pediatric Tilt Lowest Seat to Floor Height 17.5" - 19.5"2,3
Available with Manual Tilt and Recline Yes5
Standard Battery Size NF-226 or Group 246
Battery Weight 38 lbs.7 - 52 lbs.7
Available Electronics 75A Q-Logic NE
75A Q-Logic NE+
90A Q-Logic EX8
All Quantum Rehab® units can be ordered with specialty controls
Standard Charger 8A Off-board
Motor Packages 4-Pole 5 mph (Standard)
4-Pole 6 mph (Optional)
Weight Capacity 300 lbs.9
Base Weight 147 lbs.
Medicare Code Coverage Group 3:
Standard (K0848/K0849)
Single Power (K0856/K0857)
Multiple Power (K0861)
Notes 1The addition of Power Recline does not affect the allowable seating sizes.
2All measurements +/- 1/8" with 18" x 18" seat, fixed towers, 300 lbs. weight capacity and solid tires (add 3/8" with pneumatic tires). Widths may increase seat-to-floor height. Contact Customer Service for details. Listed measurements are in the lowest position; does not include elevating system unless specified.
3Power Recline and Power Front Riggings do not increase seat-to-floor height.
4Requires Group 34 batteries 5The Synergy® Manual Tilt weight capacity is 75 lbs. and maximum dimensions are 14"W x 14"D. Maximum dimensions of the Manual Recline vary by power base and seating system.
6Battery capacity may change when adding power positioning systems.
7Battery weight may vary based on manufacturer.
8Required with high-speed motors
9Weight capacity is dictated by the selection of seating.
The information contained herein is correct at the time of publication; we reserve the right to alter specifications without prior notice.
BILLSOTO1
Re: Any review on Quantum 6000z & 6400z from pridemobility.
Postby ex-Gooserider » 27 Jul 2013, 05:26
Lots of weasel worded notes, and be wary that you can't get the right software to let you set the chair up to meet your needs instead of what Pride thinks is "good for you".... Don't touch Q-logic controls as the software for them isn't available...
Also note that they "cheat" on the size specs, and give you numbers without foot riggings - the real chair will be a lot bigger and take more room to manuver.
I own two Jazzy's (didn't pay for either) and can assure you that they are both shoddily built, with undersize wiring, and generally poor construction.
Bottom line is that most of us would not take a Pride chair as a gift if there was an alternative...
Users browsing this forum: No registered users and 25 guests
