Speed button of Vr2 controller died
Postby lordk » 08 Jul 2014, 12:55
The speed button (increase) of my VR2 controller just died. I open the case and didn´t found anything broken or burn. Path and vias in the circuit board of the button and around are not cut.
Can I hard reset this board? Any help?
Regards.
lordk
Re: Speed button of Vr2 controller died
Postby ex-Gooserider » 15 Jul 2014, 10:00
Have you checked the button itself? That would be my first suspicion.....
Postby lordk » 17 May 2016, 12:14
Hi, a late reply for this topic.
The buttons (the conductive side of the physical button) are ok.
It seems to be a design fault (component failure) as a have a few more boards with the same problem. Although the circuit traces of the buttons have conductivity it seems that in some place is broken. No idea how to fix this, yet.
lordk
Postby Irving » 18 May 2016, 12:41
lordk wrote:Hi, a late reply for this topic.
Usual reason is oxidisation of the pads that the conductive button presses on to. tho a test probe shows connectivity, the probe is puncturing the oxidisation, the button can't so doesn't work. The solution is a hard pencil rubber/eraser - just rub over the contact pads till they are shiny. Don't use anything abrasive like emery paper, but a squirt of contact cleaner can help remove the oxidisation layer.
Users browsing this forum: No registered users and 51 guests
