Page 1 of 2
BM3 POWERCHAIR
PostPosted: 21 Mar 2015, 16:31
by andithornton
Hiya
Do you build for others?
Re: BM3 POWERCHAIR
PostPosted: 21 Mar 2015, 17:58
No sorry.
There are others here building custom chairs, similar, totally different and everything in between.
Re: BM3 POWERCHAIR
PostPosted: 21 Mar 2015, 18:10
by andithornton
That's a shame as I am really struggling to find something I like and am in my wheelchair all day, so it's kind of important :). If there is anyone who reads this who would be prepared to talk to me about building something please PM me. I don't have the physical ability to build myself. I'm primarily looking for range, responsiveness and reliability over speed. Oh and comfort lol.
Re: BM3 POWERCHAIR
PostPosted: 21 Mar 2015, 19:13
by rustyjames
Where are you located?
Re: BM3 POWERCHAIR
PostPosted: 21 Mar 2015, 21:23
by andithornton
Cambridge but can travel
Re: BM3 POWERCHAIR
PostPosted: 21 Mar 2015, 23:25
by nandol
John...fellas,i need a tilt actuator to make a elec.footrest....the one at pics from " evilMO" cant even lift "mis cojones" it has 300Nm...
please,post me ebay links or similar,so i can buy,obg
https://onedrive.live.com/?cid=7b7bd86f ... RzLu-U3ZCA
Re: BM3 POWERCHAIR
PostPosted: 22 Mar 2015, 00:26
Re: BM3 POWERCHAIR
PostPosted: 22 Mar 2015, 01:18
by nandol
which one should i choose from servocity ?
and from this link which is the right one ? http://www.ebay.co.uk/sch/i.html?_odkw= ... k&_sacat=0
Re: BM3 POWERCHAIR
PostPosted: 22 Mar 2015, 02:34
You need to know:
Linak bad reputation...
Voltage
Stroke length.
Shortest length rom mounting to mounting.
Newton's or pounds force required minimum
Acceptable speed.
10 newton is 1 kg or 2.2lb. Ish...
Actually its the force needed to accelerate 1kg at 9.8 metres per second per second but this is close enough.
As long as its small enough, fast enough, 12v or 24v, and has enough power (how much you need?) x2 then it will be fine!
http://www.ebay.co.uk/sch/i.html?_from= ... =&_sacat=0
http://www.ebay.co.uk/sch/i.html?_odkw= ... =&_sacat=0
Re: BM3 POWERCHAIR
PostPosted: 22 Mar 2015, 21:28
by nandol
the seat tilt actuator + footrest actuator,work with 12 or 24V ? OBG
John, x 2....?
Re: BM3 POWERCHAIR
PostPosted: 22 Mar 2015, 21:44
Yes, if you need it to be able to push with 40kg, get one that can do 80...
Re: BM3 POWERCHAIR
PostPosted: 22 Mar 2015, 22:15
by nandol
12 or 24V ?
Re: BM3 POWERCHAIR
PostPosted: 23 Mar 2015, 11:14
Your choice.
Depends how you power it.
Re: BM3 POWERCHAIR
PostPosted: 23 Mar 2015, 15:03
by Lord Chatterley
Your R-Net is set up for 12v actuators - Linak actuators are OK and easy to find cheaply. If they make a grinding sound replace them.
LC
Re: BM3 POWERCHAIR
PostPosted: 23 Mar 2015, 16:26
You can get servo ones. (they go to a position based on a pulsewidth). And they can be driven directly via a model heli gyro. So you could choose an angle via a knob (a cheap servo tester), and as you go up and down slopes or ramps the seat will stay in the same position and ignore the chair. If you get a fast ram/actuator.
Re: BM3 POWERCHAIR
PostPosted: 23 Mar 2015, 20:39
by nandol
Burgerman wrote:You can get servo ones. (they go to a position based on a pulsewidth). And they can be driven directly via a model heli gyro. So you could choose an angle via a knob (a cheap servo tester), and as you go up and down slopes or ramps the seat will stay in the same position and ignore the chair. If you get a fast ram/actuator.
r
John...put that in 'pics for me to " compreender" better. obg (isn t linak a servo ? i use linak for 17yrs = no problema... )
L.C,Can P&G Actuators sockets be adjust to 24V via OEM ? Obg
Re: BM3 POWERCHAIR
PostPosted: 23 Mar 2015, 22:02
by hank
John.
Do Sunrise dealers drop there motor prices from time to time or have a sale on
As they are cheaper at minute or is a new model out.?
Re: BM3 POWERCHAIR
PostPosted: 24 Mar 2015, 00:05
Most dealers get 30% off. And you don't pay VAT. So if you are good at dealing you can get some discount...
But no offers on parts.
Re: BM3 POWERCHAIR
PostPosted: 24 Mar 2015, 05:04
by ex-Gooserider
My experience with Linak is that they are CRAP!! Poor build, and bad engineering. Among other things they use PLASTIC for load bearing parts, and do NOT have 'End-of-travel' limits, so they can easily be overdriven. (Supposedly, they depend on detecting excess current draw in the controller circuitry, but this isn't real reliable and can cause additional problems...)
I've gotten some actuators from Progressive Automation, and have been favorably impressed by them.
As BM mentioned you need to know
Voltage
Stroke length.
Shortest length from mounting to mounting.
Acceptable speed.
Voltage can be anything, but 12 or 24VDC is usually best for chair use. If buying new, this often can be specified (but may cost a lot extra - Progressive does 12V stock, 24V is usually about $50 extra) If controlling the actuator with chair controller electronics (i.e. using the joystick) then you need to match what the controller puts out. OTOH, if using a toggle switch, then you can either use 24V directly, or go through a DC-DC (Pick one with an output current greater than the actuators maximum rating) to get the voltage needed for the actuator.
Stroke length is almost always going to be 2X the minimum length, plus some amount for the gearbox parts, and mounting bits - this should be in the data sheets. Since in many cases, the same gearbox and such can be used to make several different models with different stroke lengths by swapping out the driven shaft and tube, you will often see the lengths described as 'X plus stroke length"
i.e. 3" plus stroke would mean 9" minimum for a 6" stroke, or 39" minimum for a 36" stroke.
You also need to pay attention to the orientation of the mounting eyes with respect to the motors, and the motor mounting position, and make sure that you don't interfere with any other hardware. Some actuators can have their mounting eye orientation changed, others can't...
In general, you need to look at all the dimensions for clearance, and how you will mount the part, but the open / closed lengths are the critical ones.
For any given actuator size, there is a usually a trade-off between power and speed - more power = slower speed. Within some limits, you can get slower speed (and less force) by lowering the voltage, but it is risky to try to get more speed / force by increasing voltage, as you are looking at a motor that is working pretty hard at it's rated output.
Also as you'd expect, more force at a given speed will also mean a bigger motor and shaft diameter
In looking at the force, you need to consider both the 'dynamic' force, or how hard the motor can push / pull (note that this CAN be different for push and pull, but usually isn't) and the 'static' force, or how much the actuator can hold when there is no power on the motor - typically this will be higher than the static force, but not always.
In addition, you MUST consider the leverage and angles that the actuator will be working through, as the amount of force needed to lift the same weight will vary drastically with a change in the lever length - how to do this is more than I'd want to cover in a short post, but is critical to getting something that works.
I also like to insist at a minimum on having 'end-of-travel' switches at the travel limits, and if the actual travel allowed / desired on the device is less than the mechanical travel of the actuator then additionally adding switches at the desired travel stop points - this is especially critical if it isn't immediately obvious when at the end of travel, as it prevents burning out the actuator motor, as well as possible mechanical damage.
Re: BM3 POWERCHAIR
PostPosted: 24 Mar 2015, 10:58
Also if powering with a r-net look at max amps.
Re: BM3 POWERCHAIR
PostPosted: 24 Mar 2015, 23:04
by Lord Chatterley
Nandol,
You can have 12 actuators with a 12A limit - the lights can be 12v or 24v - not sure about the actuators.
LC
Re: BM3 POWERCHAIR
PostPosted: 24 Mar 2015, 23:14
Take a look here:
www.wheelchairdriver.com/pdf-files/r-net.pdf
Because 12A at 24V is twice as much power (better faster ram) 12A at 12V...
It is probably adjustable. No time to look gone to pub!
Re: BM3 POWERCHAIR
PostPosted: 30 Mar 2015, 11:31
by nandol
Re: BM3 POWERCHAIR
PostPosted: 30 Mar 2015, 13:03
I need some of those freewheel levers... What are they and where from?
The actuator will be slow, and its not very pretty. But will work I think. Much depends on getting the linkages and angles correct. Your blacksmith friend will get it right!
Re: BM3 POWERCHAIR
PostPosted: 30 Mar 2015, 20:13
by nandol
If you want Ivanov can make those freewheel levers for you...How many do you want?
The actuator from link above costs $50 US + 50 for shipping....I think its a good deal, dont you?
Re: BM3 POWERCHAIR
PostPosted: 30 Mar 2015, 20:38
Actuator is ugly. I would find something else. Price is OK but its messy!
I may be able to find something for levers. Will let you know.
Re: BM3 POWERCHAIR
PostPosted: 30 Mar 2015, 21:35
by LROBBINS
I was able to buy a brand new actuator for Rachi's tilt made by an Italian manufacturer (MecVel) for about E100. I was able to chose exactly the speed and stroke I wanted, and it's also pretty decent looking and all metal. That ebay one is not enough saving for something that may, or may not, have the specs you need. Figure out what stroke, force and speed you need, do a search for linear actuator manufacturers (there are lots, you may even find one in Portugal, or at least dealers/distributors in Portugal) and start to look through their catalogs. Then contact their distributors or dealers to get prices.
Ciao,
Lenny
Re: BM3 POWERCHAIR
PostPosted: 30 Mar 2015, 22:05
by nandol
Burgerman wrote:Actuator is ugly. I would find something else. Price is OK but its messy!
that would be great John...but i need 2 actuators,one for each chair,obg
Re: BM3 POWERCHAIR
PostPosted: 31 Mar 2015, 02:10
by ex-Gooserider
andithornton wrote:Cambridge but can travel
'Disambiguation needed..." There are LOTS of Cambridges - the one where Harvard and MIT are, which isn't far from me, and then there are a bunch of other ones, even over in England, or so I've heard.... :P
Seriously, if you go to the 'User Control Panel" you will find a spot where you can enter your location, which will then show up under your username on posts. It is very helpful to put at least your country and general area, as that will get more helpful answers when location matters.
Re: BM3 POWERCHAIR
PostPosted: 09 Apr 2015, 08:20
