Page 1 of 1
DX-HHP Settings for Invacare Typhoon 2 - NEED HELP! Please
PostPosted: 14 Nov 2016, 11:43
by elryko1992
I want to recalibrate my gearless motors from my powerchair Invacare Typhoon 2, i have the dx-hhp and the cable. And i want to know how i used because i don't know its for first time to me. look to the attach photo.
please if somebody know how to use exactly this please read me.
Re: DX-HHP Settings for Invacare Typhoon 2 - NEED HELP! Plea
PostPosted: 14 Nov 2016, 13:10
by rover220
elryko1992 wrote:I want to recalibrate my gearless motors from my powerchair Invacare Typhoon 2, i have the dx-hhp and the cable. And i want to know how i used because i don't know its for first time to me. look to the attach photo.
You'll need the tech pass code to login and calibrate the system.
PostPosted: 14 Nov 2016, 18:02
by elryko1992
where i found this password? please tell me
PostPosted: 14 Nov 2016, 18:53
by LROBBINS
I don't know if everyone has the same tech mode code, but I think that this might be the case. For me it was 592. (I no longer have neither a Dynamic controller nor programmer).
PostPosted: 14 Nov 2016, 19:22
by rover220
592 is correct
PostPosted: 14 Nov 2016, 19:29
by elryko1992
ok its work the password 592.. but you know the best settings to set the wheelchair? min max etc? or a tutorial
PostPosted: 14 Nov 2016, 20:32
by rover220
elryko1992 wrote:ok its work the password 592.. but you know the best settings to set the wheelchair? min max etc? or a tutorial
I wouldnt be using the hhp to do a full programming change. It's really meant for tweaking a chair that's already in working order.
PostPosted: 14 Nov 2016, 21:53
by LROBBINS
All of the Dynamic manuals are available for download at their web site. Register saying you are some kind of professional to get full access and you can get very complete programming information for whatever modules your chair has.
PostPosted: 14 Nov 2016, 21:57
by rover220
LROBBINS wrote:All of the Dynamic manuals are available for download at their web site. Register saying you are some kind of professional to get full access and you can get very complete programming information for whatever modules your chair has.
No need to register these days.
PostPosted: 15 Nov 2016, 00:42
by ex-Gooserider
I don't know if it still applies, but the directions for the MKIV controller make a big deal about being sure the chair has the drive wheels off the ground and solidly supported... I haven't tried the procedure (yet) but the manual says that it spins the wheels back and forth at various speeds, so you need to be sure they can turn and that the chair is on a solid enough support not to fall off while the test is running....
PostPosted: 15 Nov 2016, 09:04
by elryko1992
aha ok, thanks! i only calibrate the motors, and everything works great an succesfuly calibration, i put the chair on te ramp lift. thanks guys! :D
