Page 1 of 1
PUMA 40 - 6 km\h - 2014
Posted:
10 Dec 2016, 17:53
by elryko1992
Hello! I want to know if is possible to have more speed if my motors is with 6 km\h? If i buy PP1 Programmer can i do more speed? or OEM Programmer? or only to buy two motors with speed 10 km or 12? I have VR2 joystick and controller with lighting.
Re: PUMA 40 - 6 km\h - 2014
Posted:
10 Dec 2016, 17:58
You would likely need the faster motors which have taller gearing, and they are lower impedance too, so you would need to change a few settings with a programmer too. An OEM programmer, will probably be needed to change the motor compensation setting at the very least. Also there are different power output VR2 controllers. You will need to make sure yours is one of the high power ones because the faster motors need more amps to turn or climb a ramp.
Posted:
10 Dec 2016, 19:27
by elryko1992
i have two battery MK POWERED 12V 73AH, is not enough? only to change the motors? i wish 10 km\h or 8 km\h to have, because 6 km is to slow... can i do with OEM 8 km or more?
Posted:
10 Dec 2016, 20:01
The battery is the one part you don't need to change. Please try to read my post above again.
