expresso wrote:How fast i can discharge the pack with the PL 8 - ? i want to test it again - wont ride - just discharge it deep enough and recharge -
can i discharge at 10A or more a hour ?
expresso wrote:http://www.ebay.com/itm/Bontrager-5Nm-Preset-Torque-Wrench-4mm-Hex-Allen-Fitting-8401-New/252676472548?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D40130%26meid%3Df2069c06f7ac43e881f3346a02533b4a%26pid%3D100011%26rk%3D1%26rkt%3D5%26sd%3D111874799853
i got this one -
Gnomatic wrote:
Do you still have access to these cells? If so, what would there price be in USD? If any info on the background of these, it'd be much appreciated.
Thanks!
Burgerman wrote:Expresso, what was the volts of the cells BEFORE you start to charge?
Burgerman wrote:Its likely a loose screw, one of any of them... Or it might be nothing more than the resistance of your charge lead / harness. After a few miles if all voltages are pretty similar, say half discharged, then don't worry.
3.148V - compared to 3.150 just 2mv! Thats just a 500th of one volt! If they were 15 to 20mv apart I may worry a tiny bit.
Burgerman wrote:Check ALL. If you failed to solder any connections and relied on a crimp (spits! shakes head), that can also be a problem and unless done exceedingly well, and it usually is the problem...
Burgerman wrote:Resist the temptation to touch your tongue on those terminals.
Users browsing this forum: shirley_hkg and 165 guests
