Burgerman wrote:Then order a strip of 1mm alloy sheet. Same width as the gap+ the indented smaller diameter part of the wheel cut to size, that is the same diameter as the indented part of the black drum, x pie, and bend in a circle. Use alloy brazing rods to join up, and then to attach to the spacers. To make a ring with spacers attached. You are done! Bolt on stock wider outer rim.
Burgerman wrote:http://www.sinopolybattery.com/main/prodetails.aspx?CID=10&ID=367
How can I get 8 of these?
Users browsing this forum: Bing [Bot], Burgerman, Google [Bot], shirley_hkg and 150 guests
