New chair!
Re: New chair!
Postby Burgerman » 10 Mar 2017, 19:54
You need:
A USB to serial adapter unless your PC is old.
A programming cable that you need to make - its easy.
A Dwiz adapt possibly. Depends on the controller. Some have that built in.
Re: New chair!
Postby salam321 » 10 Mar 2017, 20:40
i already bought the dwiz cable and a dwiz adapt, now i need to connect them with my laptop, unfortunatly mine is new one, so i guess what's left is a USB to serial adapter, what you think about these:
http://www.ebay.fr/itm/Cable-Assemblies-Smart-Cables-CABLE-USB-DB9-MALE-RS232-10CM-/282287592581?hash=item41b9a6d485:g:~qMAAOSwnHZYTO4y
http://www.ebay.fr/itm/Computer-Products-Converters-Interfaces-ADAPTOR-USB-RS232-CONVERTER-FTDI-/272481898744?hash=item3f712fd0f8:g:Gv8AAOSwOtdYTO5B
Do they work ?
salam321
Re: New chair!
Postby Burgerman » 10 Mar 2017, 21:58
The FTDI ones will. But those are stupid prices. I paid 10x less for two!
Re: New chair!
Postby salam321 » 11 Mar 2017, 03:08
here another one
http://www.ebay.fr/itm/Adaptateur-Convertisseur-Usb-a-Db9-Serie-Rs232-Rs-232-Adapter-pour-Notebook-PC-/252379372957?hash=item3ac2fb9d9d:g:TMIAAOSwTuJYts13
anyway, i was wondering if my storm has a lighting module in it, on the joystick i got all the necessary buttons and flashing leds..same thing with the lift, should it be only activated somehow, or do i need much more than that..sorry if i interfered in your subject
salam321
Re: New chair!
Postby Burgerman » 11 Mar 2017, 10:12
FDTI only.
Storm? Maybe.
Re: New chair!
Postby hank » 11 Mar 2017, 21:02
Burgerman wrote:Then order a strip of 1mm alloy sheet. Same width as the gap+ the indented smaller diameter part of the wheel cut to size, that is the same diameter as the indented part of the black drum, x pie, and bend in a circle. Use alloy brazing rods to join up, and then to attach to the spacers. To make a ring with spacers attached. You are done! Bolt on stock wider outer rim.
John
Any luck alloy brazing the rings you made for wheel centres on Brushless wheel mod.
If yes which make of rods did you use.
Re: New chair!
Postby Burgerman » 11 Mar 2017, 21:23
I riveted them...
Re: New chair!
Postby hank » 11 Mar 2017, 21:27
:lol: :lol: :lol:
If it works good enough.
Did you duck tape over joint.
Re: New chair!
Postby Burgerman » 11 Mar 2017, 21:41
Nope, sprayed 2 coats of black wrinkle paint, and fitted them. They are a perfect fit, don't look pretty but they are unseen.
Re: New chair!
Postby hank » 11 Mar 2017, 21:47
Perfect 8-)
Cheers i am on it nxt week. ;)
Re: New chair!
Postby ThomasKaeding » 12 Mar 2017, 14:45
Good morning Burgerman, congrats on the new chair! I know you will make it your own special breed in no time at all. What motors are in your new chair.
TK
ThomasKaeding
Re: New chair!
Postby Burgerman » 12 Mar 2017, 19:21
The only reason I purchased it, brushless, 3rd version, lots torque, controller 125A.
Re: New chair!
Postby ThomasKaeding » 12 Mar 2017, 22:07
Do you know the model # of the motors. I'm still working on the design for a chair for a close fiend.
ThomasKaeding
Re: New chair!
Postby Burgerman » 12 Mar 2017, 22:22
Yes. Invacare, latest as used on Storm 4 Explore, with the same brushless controller.
viewtopic.php?f=2&t=6642&start=60
Re: New chair!
Postby shirley_hkg » 27 Apr 2017, 02:22
Started using it ?
Re: New chair!
Postby Burgerman » 27 Apr 2017, 09:39
Couple of times, but been doing filthy jobs in old chairs and now its raining daily and its big indoors...
Re: New chair!
Postby Rye » 03 May 2017, 02:45
Cool chair. Have you watched the promo video on the website? lmao. It looks and sounds like a Paul Oakenfold music video. Let us know how smooth a ride it is.
Rye
Re: New chair!
Postby Dan » 07 May 2017, 16:54
The manual for the storm 4 says the seat height with the raiser can go as low as 40CM. Is that true? The Quickie Salsa M seat height is 47CM, the difference would mean a lot for me.
Seat height *** (with lifter)
40 - 65 cm
Seat height *** (without lifter)
45 / 48 cm
I am temped to get one.
Dan
Re: New chair!
Postby Dan » 07 May 2017, 17:49
Is it easy to get them reprogrammed?
Dan
Re: New chair!
Postby Burgerman » 07 May 2017, 20:00
very.
Re: New chair!
Postby CPguy » 09 May 2017, 09:56
@ Burgerman: I would like your opinion please: Is it possible and sensible to mount a 16x6.50-8 4 Ply Kenda K500 Super Turf With K-SHIELD tyre (https://allterraintyres.co.uk/index.php ... bdf134e5b6) on the BLGL Invacare motors if I need a tyre that works well in rain and snow? Would I need a tube?
I am being offered a “Bopper” (picture here: http://motorrad.michelin.at/reifen/michelin-bopper#dim) on a 10 inch rim. But I am not convinced by the tyre thread.
My rides:
2 Progeo YOGA (for traveling)
CPguy
Re: New chair!
Postby Burgerman » 09 May 2017, 10:08
I am not sure how rigid the motor drum, or shaft or bearings are. It might be fine. Without trying it and accepting the risk we will never know. I widened mine slightly, from a 3 inch tyre to a 4.5 inch tyre. That only moves the centreline of the tyre by 20mm. So shouldn't change the loading much. Your risk! It may be no problem. Or it may cause the drum/magnets to hit the windings/centre parts. Who knows! Test and see!
Re: New chair!
Postby CPguy » 09 May 2017, 12:05
Will do, boss! Thank you for explaining the risks.
My rides:
CPguy
Re: New chair!
Postby shirley_hkg » 09 May 2017, 12:50
I'd worry the thread base for your long bolt is not strong enough It is aluminium .
Re: New chair!
Postby Burgerman » 09 May 2017, 13:31
Well the lifter is bigger and wider base than the storm4 one, and they never failed. As far as I know! :o
Re: New chair!
Postby shirley_hkg » 10 May 2017, 03:07
Burgerman wrote:http://www.sinopolybattery.com/main/prodetails.aspx?CID=10&ID=367
How can I get 8 of these?
Found this close clone .
Internal Resistance seems low , doesn't it ?
Price tag , @£45.00
Re: New chair!
Postby Burgerman » 10 May 2017, 09:49
Re: New chair!
Postby shirley_hkg » 10 May 2017, 11:56
Haven't you said that it had 346mm max ?
Then , it will take . 2 rows of 4 , whereas SINOPOLY is one row of 8 .
You did mention the space you have , but it's buried deeply out there .
Re: New chair!
Postby Burgerman » 10 May 2017, 16:33
260
242
190
Group24 x 2
Users browsing this forum: Bing [Bot], emilevirus, foghornleghorn, yeshelp and 105 guests
