Gnomatic wrote:shirley_hkg wrote:
At 38A , only the two 10awg wires have some mild temperature and the Dsub connectors are dead cold
I used 12AWG for my main charge wires in my charging cable. That's what Revolectrx sells. I assume that's ok, as they put 40A fuses in them. My charge cables are 4ft on the charger end. Will 6ft charger to battery cabling be ok charging near 40A is 12 AWG charge wires are used?
Is it possible to use 10 AWG wiring in those stackable safety banana plugs like the PL8 uses? The ones I picked up say 4mm outside cable diameter max. The outside of 10 AWG wire is just a bit more than that from the charts I looked at.
expresso wrote:yeah thats what i am afraid of - dont want cheap ones - that will melt - the ones Genomatic linked too are nice - good price - but no Amp rating -
Burgerman wrote:Did you think about making an extension. 4 of the connectors, and one 36 inch ready made balance lead/extension.
you mean two connectors ? they come 2 feet
Gnomatic wrote:expresso wrote:yeah thats what i am afraid of - dont want cheap ones - that will melt - the ones Genomatic linked too are nice - good price - but no Amp rating -
I asked the seller, they told me those connectors are 32A rated.
Which butt connectors did you use to extend those Revolectrix cables w/ built in fuses?
Burgerman wrote:You are making it over complicated. Buy the ebay 4mm ends!!! And a ton of silicone cable.
shirley_hkg wrote: BM , would you please include the followings in your suggestion list to REVOLETRIX
1,more balance starting points
2,Soft start for all charge current ; for sake of power supply and initial charging for deeply discharged cells . ( now I enter low charging rate in preset and change to higher amp after start . It then increases at around 0.5A steps . )
Termination @150 mA already , THAT is 1500th /C for a 216Ah pack .
i charged last summer at 35A - each day since i use it alot - love how fast i can refill the whole packnow that i added an exta 30ah to it - i can lower it a bit and still finish it full in same time - charging etc on there own - 12A to 15A for the add on and 20A to 25A for the full pack -
i still love how fast it charges from empty
Users browsing this forum: No registered users and 160 guests
