Gnomatic wrote:So, if the ADD ON on a lead brick chair gets down to 2.9v/cell, then both the ADD ON pack and lead bricks are at 23.2v, correct?
When a lead brick chair reaches 23.2v, about what % of available capacity is left in the lead bricks?
Dan wrote:Are the cables from the pack to the charger used for anything else? Could you just run long cables from the pack to the charger than when its charged roll it up and place it in the bag with the pack?
expresso wrote:Yes you can do that also - you can by pass even making a Sub D connector - you can make a long cable power Leads from the PL 8 to the battery pack - and also the same with the Balance wires - using the 36 inch cables - - -
Dan wrote:expresso wrote:Yes you can do that also - you can by pass even making a Sub D connector - you can make a long cable power Leads from the PL 8 to the battery pack - and also the same with the Balance wires - using the 36 inch cables - - -
I know its nowhere near as neat and tidy but after blowing of the dust from my soldering iron and trying to solder the Sub D connector I found that unfortunately I no longer have the strength or dexterity to get the job done.
I may find someone local to do it or just go down the rough and ready road of a longish lead on the pack.
snaker wrote:@expresso: Can you take and post a pic of the cable that connects between the PSU and the PL8? And what AWG size is it?
