Dan wrote:My cells arrived yesterday. I guess the first thing to do is charge them up then leave them be a while.
Do I have to charge them individually? what are the settings for the PL8?
shirley_hkg wrote: I wouldn't recharge an empty cell @0.5C .
Good luck , again .![]()
Just finished charging up the Lead Alone for the first time in years - since i connected the ADD ON -
got back 28ah - so its still OK - if you used it alone - its not good at all - but with the ADD ON - i get 25 miles still - i was expecting less than 28ah returned
So I got my cells and charged them up and left them to discharge by themselves for a bit. I believe this is done so that they can be sorted into groups that hold about the same amount of charge that can get charged evenly by the charger?
Dan wrote:So I got my cells and charged them up and left them to discharge by themselves for a bit. I believe this is done so that they can be sorted into groups that hold about the same amount of charge that can get charged evenly by the charger? This is why the PL8 charger has balancing leads, so it can give a little bit extra to a group of cells that have less charge?
This would be groups of four?
There are 9 leads in the balance cable. Red at one end and black at the other with white inbetween. What way do the cables work and what is the best way to number them?
I'm building a little 16 Cell with 15ah Cells.
My next big question will be how do I fit it to my chair? Its going to be a Invacare storm 4 xplore. I will want to be able to charge them together.
Users browsing this forum: No registered users and 107 guests
