expresso wrote:
so if i connect both my chargers on the 24V unit - i can saftely charge two chairs at 30A each ? since its 75A - if thats the case - i can make longer charge cables - in the future - organize the chargers - stack them somehow - one PSU - i can vision it - dont think i am not in a rush to need everything done at once same time - but would be fun
You could run both chargers and get 30A out of each charging. PSU would be working twice as hard, buy since its rated @75A it should have enough headroom.
sad_vampire wrote:I use a SKYRC eFuel 1200w, 50A PSU, 15-30V
https://www.flyingtech.co.uk/accessorie ... cd-display
expresso wrote:nice good to know - - now with the 12V PSU - i am not sure what that was rated at when i purchased it - i like to say 75A - but it may not be - with that one - what would be the max for each output ?
if i charge at 19A to 20A max - i leave it at 15A charging with this 12V - unless i up the charger a bit - it may give me a bit more - but dont want to max everything out just for a few extra Amps -
so with the 12V - 9A each would be the max then - if i am correct ?
Gnomatic wrote:You might be able to charge at higher amps with your 12v PSU than you're able to now.
expresso wrote:sad_vampire wrote:I use a SKYRC eFuel 1200w, 50A PSU, 15-30V
i like this one also - at some point - maybe one of these or silimar may come in handy for me - as long as my Ebay models are working and they still make them - its the least expensive option with two outputs and 60A now -
but i like having one plug also and compact - i like having those extra 10A outputs also -
now with this unit - if you connected all those outputs - the Main 50A - and the other 3 all at the same time - how much can you pull from the Main then ? 20A max and 10A for the other 3 for a total of 50A ?
expresso wrote:so is 50A on the charger PL 8 - OK - leave it there ? or lower ?
Burgerman wrote:Unlessthe server supply is less powerful than it is claimed?
expresso wrote:Sorry to hear that - your PSU failed and not up to spec - since i recommended them i belieave - and in my case - i could be lucky - i have 2 of them - and both so far - working fine - but your right - warranty wise is very short -
cost wise is about half of a new unit - but may be worth getting a new unit with your experince with these - i am thinking of getting another Ebay model 24V now - but not ruling out a new unit either - i like a small unit that the new ones are and with one cable - but most are at 50A max also - - still good - means you cant charge at 40A but 35A should be fine
Users browsing this forum: Bing [Bot], Seafighter, shirley_hkg, tettralytic and 119 guests
