expresso wrote:Best thing to do is find the manual on your chair which can explain how to go into this Mode and how to Navigate it - just guessing how it should work - may not work at all and you dont want to change something else your not sure of - find the manual and follow the instructions - Rnet has same thing and instructions in there manual to follow
unless Pride dosnt allow users to download there manuals or repair manual etc, - which i wont put it past them - - try to find the manual for your joystick - chair etc, and take it from there - if its locked out - then you need someone to come and enable it first -
rover220 wrote:I may have a programmer available if of interest.
Soulrider wrote:rover220 wrote:I may have a programmer available if of interest.
I'm interested. ButI have a LOT of questions. Does it work with the Quantum Q6 Edge 2.0? Have you tried it recently to make sure it still works? What type of programmer is it? Is it a handheld version and if so does it have the part number: ELEASMB6976 on the back of it? I was lead to believe that old ones that were out there didn't work anymore as they went to some cloud based, passworded system. But, I know they do still have hand held programmers that still work as I had a tech out the other day that used the ELEASMB6976 programmer to make some changes on my chair.
Burgerman wrote:The min turn acc and turn dec are all set way too low for accurate control on that list above.
Burgerman wrote:And its better to have all the turn decelerations set to as high as possible, and at least as high as turn acc settings.
Wouldn't this end up being an "all or nothing" setting? So, if maxed at 100% then you are full on and if you let up you are full stop?
Burgerman wrote:Didnt you already pay for one?
And is your chair Qlogic2 or Qlogic1 or Qlogic3? or what? There are several options.
Twinpanther wrote:Not sure if this helps at all for the moment. You sound like you are comfortable with no restrictions as I am. Here is a list of the power settings of my Q6 Edge (first model). These settings worked well after I got them set to my liking. I have a handheld programmer as well. Older version (They had a second hand controller come out before the Q6-2. It is very faint to read but it works great (for my chair). Anyway, just wanted to show you what I had set until you can get your programmer in your hands. No more crushing knees into desk legs or holes in a wall because it didn't turn when you wanted, lol.
Burgerman wrote:(SNIP..) Heres my rough order before speaking to the sales rep. And adding a few more bits... Then pay, wait. 3 to 4 weeks delivery from germany. Due to custom stuff, black paint etc. Be here 19th Jan.
http://www.wheelchairdriver.com/ordered.pdf
Burgerman wrote:It was always far simpler here. But you had to rely on "their" assessement and choice. Thats was it. So I argued rather a lot and was the first erson 7 years back on a personal budget. Since then its been rolled out in many areas. I can use money to buy new/used or build my own. Giving the user the bying power makes dealers and manafacturers take notice...
Item that indicates that the system modules are being configured. Shows animated
bar below.
woodygb wrote:Q-logic 3e.
https://www.pridemobility.com/pdf/owner ... boi_om.pdf
Page 17Item that indicates that the system modules are being configured. Shows animated
bar below.
20 SW Fault: Wrong profile version of remote device
Incompatible module connected.
Remove incompatible module or update the software.
The PCPS also has additional capabilities, including: saving/restoring sets of parameters to/from disk, updating
Q-Logic software, and programming IR remote controls.
For more information, see the instructions included with the PCPS software.
FelipeOliveira wrote:woodygb wrote:Q-logic 3e.
bar below.
good morning woody. Thank you for your help. now, it's indicating. “ Error Code 20 SW Fault: wrong profile version
of remote device” unfortunately the chair is not here with me yet, but it will be soon!! Is there any function, like reset? or restore ?
woodygb wrote:I have no real idea how you update or reset the software on Prides Q-Logic.
I have the one you helped me with about 3 years ago and I never used it again lol. but anyway I have to wait for the client to bring it to me.
Here is the blurb from the pdf.The PCPS also has additional capabilities, including: saving/restoring sets of parameters to/from disk, updating
Have you got the 1314 PCPS Software and CanBus programming cable?
thanks again !!! I will study these PDFs, while the chair is not enough. it will be perfect, she arrives and I already have the solution!!
Users browsing this forum: No registered users and 11 guests
