Gnomatic wrote:The one I use has only two wires; seems to work well enough.
shirley_hkg wrote: Better leave it ON all the time .
Unlike cell alarm , it won't cause imbalance amongst cells .
why would the Cell monitor drain it and Volt meter not ?
expresso wrote:IF left on all day for 40 miles - would it drain alot or nothing to notice ?
snaker wrote:expresso wrote:IF left on all day for 40 miles - would it drain alot or nothing to notice ?
Mine consumes 20mA. If left on 24h, it will eat about 24x0.02 = 0.48Ah. Very small for the whole pack
snaker wrote:I also fitted an inline fuse to protect the expensive controller. We do not know what will happen with cheap gadgets
Burgerman wrote:If its got thin wires going to it, dont worry.
i did it already no fuse - its only going to used to show the Volts - and it works so far - not sure how accurate it is - mines seems to change as move it - i have to see how it works when in use -
Gnomatic wrote:BM's XLR preset for 24v MK gel is 12A max.
Burgerman wrote:i did it already no fuse - its only going to used to show the Volts - and it works so far - not sure how accurate it is - mines seems to change as move it - i have to see how it works when in use -
Of courseit changes as you move. You draw Amps from the battery. All batteries have resistance. Lithium will change very little. Lead changes by up to 6 voltsas you wheelie or turn... Voltage drops under load.
My presetcharges at12A max, works great. Thats the max allowed by the charge port and by the manufacturer of the control system.
Burgerman wrote:Mmmm. Shouldnt move at all.
Users browsing this forum: No registered users and 564 guests
