You would think it was a different model chair now.
What pressure you running about 20-25 psi in rears.
shirley_hkg wrote: That skinny grey tyres make it really looks
" handicapped " .![]()
Burgerman wrote: How about now?
Burgerman wrote:Yes. Its 27.75 inches and thats with a 10mm gap to the motors.
However I intend skimming about 7mm per side off each spacer leaving 3mm or 1/8th inch between tyre/motor case. So final width will be 14mm or half inch, less. So about 27.4 to 27.5 inches.
For a small person this would be a bad plan. Your chair would end up wider than need be. But when you consider that I am 20 stone plus, and use 18 or 20 inch cusion, and that with the "comfort" parred P shapes arms the chair is 27.5 wide anyway! So not a lot of advantage in a narrower tyre width. Now it all matches... So in my case this doesent make the chair wider. In most peoples cases it would.
And at 20psi it feels about right. Maybe 2 less. Nice big soft tyres deform and give a smoother ride than 36psi stock grey skinny ones. And of course these are a lot stronger and no tubes to pop/leak. So all around fair bit better for my purposes. And they look pretty good in real life compared to pictures.
Burgerman wrote:Gone ofF heideneu whatever they are called tyres. One keeps deflating, at the rim and they say tubeless but I dont think they are. The beads and interior do not look tubeless. Maybe fake? So ordered a set of proper ones!
Users browsing this forum: Superchunk, ukralex and 484 guests
