anywhere’s from 8mins to 60+...
Burgerman wrote:anywhere’s from 8mins to 60+...
Let them finish. What is mA termination set to? Should be 15mA ideally according to spec, but if you change it you need to do all again. If its set higher thats ok too, but will result in a faster end. If doing loads I often set it higher and may have done for expresso. Set a 4 hour limit for CV timeout.
Burgerman wrote:Then CV should easily end in under 2 hours if the cells are healthy. Probably a lot less if they were quite charged. Let them all charge till they reach termination point.
Burgerman wrote:Is it dropping? Look at the amps graph. It certainly should.
snaker wrote:@hotwheels_75: take some close pics of your cables that you are using to connect between the charger and the battery and also between the charger and the power supply too. Someone here might check if terminals were properly done?
Burgerman wrote:Very strange. Call it done, mark the cell with a question mark. The headway manufacturer says charge to 1000thC which is 12mA. So it should easily reach that. But its not falling as it should.
steves1977uk wrote:I have the following PSUs...
https://www.amazon.co.uk/SKYRC-Efuel-12 ... B00ISTUAFA 15v-24v selection, 60A max at 20v otherwise 50A at 24v. Paid about £170 for this PSU from eBay.
Burgerman wrote:Run it from a battery to test. But all those errors, and your non ending charge suggest a bad connection between cell and charger.
Soft start is an error that means the power supply often a generator cant keep the voltage stable as the charger ramps up power. That may be power supply related. Are you using good, soldered connections everywhere? And proper safe banana connections to the charger, not those cheap ebay connectors?
steves1977uk wrote:I've been using my PL8 with the EC5 connector left intact without any issues, even when charging at 40A. Why not make a PP75 to EC5 short lead ex-G? That way if you have any issues with the PL8 while under warranty, you'd be able to return it unmodified.
hotwheels_75 wrote:steves1977uk wrote:I have the following PSUs...
Hi Steve, have you used your eFuel PSU much? Have you had any problems with it?
Users browsing this forum: emilevirus, slomobile and 86 guests
