Burgerman wrote:Does it also say tubeless on the side? It may not as its a different size.
Yours may be genuine too! Mine may be fake...
Burgerman wrote:No image?
Burgerman wrote:I ordered a set of Duro tubeless 120/70 - 8, an hour back. Of course it could be the rims? But thats unlikely. Its easy to get dimensions right in alloy! I am going to measure them.
snaker wrote:BM, my chair is like in the below pic. Its seat can be moved backwards about 8cm. Should I move it as far as possible? Or is there a formula to calculate the right position?
Burgerman wrote:It should not be possible to push tyre off rim regardless even if deflated. I suspect the tyre isnt legitimate...
YES . It should be real tight . We usually need some leverage to push the bred out , when change tyres .
Hate a half done a job!
But it better look finished. And neater to have them hold the centre disk too. And of course the disk is stainless steel! It actually looks better in real life than a photo with flash. All really well finished.Burgerman wrote:Theres 2 sorts of work. Goodwork. And badwork. I like to do goodworkHate a half done a job!
No centre, and rust prone hex bolts would "work" equally well. (badwork). But would bug me indefinitely!
Burgerman wrote:£9 each!
Burgerman wrote:The rims are 9 uk pounds on the chinese version of ebay... Shipped by shirley to me.
Those tyres are 50 uk pounds!![]()
Each!![]()
But are very strong, tubeless, high quality scooter race tyres. You get what you pay for in this case. Good construction, radial, and proper rubber with steel banding on beads. You wouldnt trust your life at 80mph on a bend with cheap mobility/kenda/chinese copy tyres!
Users browsing this forum: No registered users and 47 guests
