Burgerman wrote:Same as headways.
foghornleghorn wrote:The adjustable end is a rose joint.
Burgerman wrote:And the bars are 14 or 15 mm alloy bar...
https://www.ebay.co.uk/itm/Round-Bar-Ro ... oY5XgtvA0A
Burgerman wrote:I buy 3 meter lengths. Usually 15mm or 16mm. If you want fancy, use carbon fibre bar...
To drill, I have a lathe in my bedroom.So drill, tap, easy. 6.7mm hole.
Burgerman wrote:Not with grease. Or copper grease.
Put any dry metals together and then allow water, or worse salt water and you have a battery. That means lots of chemical reactions happening. Grease stops that. And lubricates the threads on tightening or removal. Threads need to be greased. On any new chair they are dry...
Burgerman wrote:The solution is programming.
Graphite grease will be OK. If a little messy. Dont use it on bearings.
If you weigh all the power footrest and backrest actuators and linkages, the seat mountings, lift and tilt module, extra electronics etc you will see it adds 50 to 70kg...
Burgerman wrote:The limiting part is that horizontal bar across the rear, at te top, where the battery slides in and out. What is the measurement from the floor where the battery sits, to the underside of that bar?
Users browsing this forum: emilevirus, Red Dragon and 191 guests
