QUADPHONICS wrote:what I mean is I use a lithium ion battery in my Bounder plus power chair .
There seems to be some misunderstanding regarding the linked study. It definitely does not indicate a number of cycles in the range of 40000. Instead, Table 2 shows e.g. the total amount of charge taken from the battery is 3610Ah, corresponding to 1128 equivalent full cycles, when a partial discharge of 60% total capacity starting at 75% state-of-charge is used, i.e. from 75% to 15%.
QUADPHONICS
(1) Revolectrix Cellpro PowerLab Plier Clip Assembly
Burgerman wrote:I have these. Well made. http://www.canford.co.uk/Products/20110 ... try-nickel
>>>Singapore store?
Burgerman wrote:A battery in a car, anything from 12 to 30V works fine. You need a 35 A or more and 24V up to 30V to get maximum power which is a lot. But you can also run it from a smaller supply.
Hello Paul,
We have received your order online. Thanks for your business.
For the reason that Headway facotory temparily stop their plan to produce more 38140S 12Ah model since Jan(they said the demand is much lower than their other models), right now we only have some stock for this model. They don't produce it and may no longer produce this model even we order a lot.
So we are sorry for the inconvenience, and we suggest you to think about if you can use 38120S 10Ah model or 40152S 15Ah model which we can ship immediately.
Sorry for the inconvenience. And please kindly let us know your advice and we will work on it accordingly.
garriew wrote:Burgerman wrote:A battery in a car, anything from 12 to 30V works fine. You need a 35 A or more and 24V up to 30V to get maximum power which is a lot. But you can also run it from a smaller supply.
Would this be a good PS?
http://lipoconnectionsolutions.com/HP-2 ... 241500.htm
If yes, what would you chose for the charger type? and other options?
Mind The Gap wrote:UpdateHello Paul,
Have updated order to 58 40125s with 4 hole connecting plates, waiting for repy.
Paul
Did you order it w/ bullet connectors?Gnomatic wrote:I have that PSU with an EC5 connector. It works well enough with my PL8.
garriew wrote:Did you order it w/ bullet connectors?Gnomatic wrote:I have that PSU with an EC5 connector. It works well enough with my PL8.
Users browsing this forum: fishinjunky, swalker, Yennek and 510 guests
