Postby nSRaiden » 09 Feb 2018, 10:14
woodygb wrote:You program via the charging port of the joystick pod.
The joystick pod AND the control unit MUST be connected together .
They must be connected to 24v AND the pod must be TURNED ON.
i agree for the charging port for programming but the yellow wire connected to the rx/tx port on XLR side goes nowere on the PCB see the picture it seem the controller as been modified by the previous owner
for the 24v i powering the controller with 12v it's one of y mistakes :mrgreen:
nSRaiden
Postby woodygb » 09 Feb 2018, 10:16
12v maybe fine.
The brain is inside the control module and the joystick pod is dumb.
The yellow INHIBIT / Programming wire doesn't connect inside the pod ...it connects inside the control module.
Postby nSRaiden » 09 Feb 2018, 10:20
woodygb wrote:12v maybe fine.
any clue where its connected ?
because mine is connected to nothing just cutted off
nSRaiden
Postby woodygb » 09 Feb 2018, 10:22
Yup ...The brain is inside the control module ...the joystick pod is just a dumb control box.
EDIT :- DYNAMIC control systems have ...as I recall.... a brain in both the pod and the control module.
Postby nSRaiden » 09 Feb 2018, 10:31
but this not explain why i have 2 wire chopped off on my cable and where this two wire go normally
i have checked in the 4 hole plugs its red green purple black
nSRaiden
Postby woodygb » 09 Feb 2018, 10:50
I haven't played with a VR2 with the extra functions.... mine has just 3 wires ( 3 pin plug and socket ) POS /Red , NEG( GND )/Black and a White signal wire plugged to the board.
My Yellow goes to the XLR pin 3.
Postby nSRaiden » 09 Feb 2018, 10:53
woodygb wrote:I haven't played with a VR2 with the extra functions.... mine has just 3 wires ( 3 pin plug and socket ) POS /Red , NEG( GND )/Black and a White signal wire plugged to the board.
did you use the same plug as mine?
nSRaiden
Postby woodygb » 09 Feb 2018, 11:22
I do not know what plug your referring to.
Postby woodygb » 09 Feb 2018, 11:27
IGNORE the RED and BLACK wire in the second pic ...these are MY additions.
Postby nSRaiden » 09 Feb 2018, 11:28
woodygb wrote:.
the 4 hole one on the vr2 side
nSRaiden
Postby woodygb » 09 Feb 2018, 11:39
See pic ...mine is 3.
Postby nSRaiden » 09 Feb 2018, 11:53
on this side
can you give me a picture of the end of your cable because mine must have a connector in less because if the yellow wire is connected to the controller on mine is cut and goes nowere
nSRaiden
Postby woodygb » 09 Feb 2018, 12:20
Your not making any sense to me.
The YELLOW is the programming/inhibit lead ... it goes to pin 3 of the charging socket.
You need GND and the YELLOW for programming and everything turned ON.
Postby woodygb » 09 Feb 2018, 12:32
On your pic you say ...
Here is my pod
..NO that is the control module.
Your 4 pin plug goes to your joystick pod.
The only type that I have seen has just 3 pins.
Postby nSRaiden » 09 Feb 2018, 12:37
woodygb wrote:Your not making any sense to me.
I'm looking for where he's supposed to go as he's not going
i think this cable have been modified by someone
it means that in one of the 4 pin on the big plug is yellow on your cable
nSRaiden
Postby woodygb » 09 Feb 2018, 12:51
I do not know how to help you.
I can only point you back to my posts about how mine is wired up.
Postby nSRaiden » 09 Feb 2018, 12:53
woodygb wrote:I do not know how to help you.
yellow is connected in the pin 3 in the big connector
black white yellow red
now why my com was always inactive
controller on
i'm using a prolific USB serial com port with the diode
i think i don't have missed anything but it's not working czy
any parameter to change like baud rate?
nSRaiden
Postby woodygb » 09 Feb 2018, 13:18
Postby nSRaiden » 09 Feb 2018, 13:39
woodygb wrote:YUCK! Prolific is a PITA.
http://www.miklor.com/COM/UV_Drivers.php
i know but this is the only com adaptator thing i have on hand i already use this driver
i have tried this without any result czy
nSRaiden
Postby woodygb » 09 Feb 2018, 13:49
Sadly I cannot help any further other than recommending a specific FTDI lead.
TTL-232R-3V3-WE
download/file.php?id=7152&mode=view
viewtopic.php?f=2&t=2111&start=1040#p109600
Postby nSRaiden » 09 Feb 2018, 14:03
woodygb wrote:Sadly I cannot help any further other than recommending a specific FTDI lead.
TTL-232R-3V3-WE
thanks i go buy this and cross my fingers thanks for your help
nSRaiden
Postby dglewis80 » 10 Mar 2018, 10:46
Hi all.
I've just got my hands on a power scooter that I wish to clean up and give to my parents, the only problem is it has been programmed for the previous owner to travel at less then walking pace.
Thanks to this forum, I've been able to make the cable, which I have tested with the service version of the software and can read the S-Drive controller with no issues.
The question I have, and I hate doing this with my first post, but has anyone got a working link to a version of the software that will allow me to make changes?
Thanks in advance, Dave.
dglewis80
Postby Burgerman » 10 Mar 2018, 10:47
See pm.
Postby nSRaiden » 29 Mar 2018, 21:50
TTL-232R-3V3-WE
have puchased the cable but the programmer software stay Innactive i'm waiting for my new battery i'm going to try with 24v i think it's the last issue i can have with this controller if this not work any of member of your community have a clue about hacking the pwm controller with an arduino?
nSRaiden
Postby woodygb » 29 Mar 2018, 21:59
Have you looked in Windows Device manager.?
Has the FTDI driver installed correctly?.
Did you know that the COM Port number assigned by Windows to the lead MUST be between 1 & 8 inclusive as the programming software will ONLY work with those COM Port numbers.
Did YOU tell the software which COM Port number to use? ... the software will not find it for you.
Postby nSRaiden » 30 Mar 2018, 00:02
yes for all no error in driver manager i have try 1- 8 as com and selected the port in the program with no result just stay innactive
nSRaiden
Postby nSRaiden » 30 Mar 2018, 02:21
got it just opened the controller and solder wire inside and magic it's active
nSRaiden
Postby Digipro » 11 Apr 2018, 13:35
Hi nSRaiden when u say u had to open your controller and solder a wire, what do I mean by this ?
I am having trouble with connecting to my s drive 200a as it does not seem to connect to the controller although the software recognises the cable and tries to send data.
would be good to know what you ment by soldering a wire in the controller.
steve
Digipro
Postby expresso » 19 Apr 2018, 16:45
Hi Woody - i sent you a PM - not sure if you can help -
Postby woodygb » 19 Apr 2018, 19:26
I can't see one ...but I may have deleted it as I recently had a clear out of the inbox.
Users browsing this forum: Burgerman, JMGarage, LROBBINS, sergey0, Superchunk and 126 guests
