636, 646 Wheel Hub Adapter
Postby expresso » 10 May 2018, 14:04
Ok Shirley - i decided to start a new trend here so not to change subject over at the other one -
thanks for helping to get me a hub for my chair - maybe if all works well - i can use those rims you get there also -
first i want to understand something - my chair is about 26.5 inches wide now - i dont want to make it wider - i am using the stock rims with 3.50 x 8 tires as you mentioned you used before with tubes .
i cant complain so far - chair runs good - looks good - i got rid of the front wheel wobble - 90% of the times - i get a little here and there - but nothing to worry about - so overall - its not bad -
if you made me the hub and got me those rims - i like to keep it the same width overall - 26.5 inches wide - can that work with the new rims and hub ? would i need a different size tire with OD of the stock size and same width of what i have now - if thats possible
first off here is a picture of the chair - and links to the parts list which shows the hub part number to be the same on both chairs - i have the newer motors - its 3 years old - I dont have the older larger motors - but when i look it up - it does show the same hub part number for both older and newer motors
so i would say the 636 you can use there would be the same as i have -
take a look -
thanks again - i know we talked about in the past - and you were busy getting BM and Steve rims tires etc, , if this can be done and it would be a simple wheel change for me here - maybe i can manage that then - as long as all i have to do is just get the tire mounted to the rims and then just swap tires rims off the chair -
Re: 636, 646 Wheel Hub Adapter
Postby expresso » 10 May 2018, 14:05
here is the link to the parts for the hub - looks like number 5
https://www.quickie-wheelchairs.com/rep ... -s636-s646
theres no rush - when ever you can -
Postby Burgerman » 10 May 2018, 14:54
The limiting factor is the motor can in most cases. It means a tyre cannot go inwards as it will hit the motor. So take a look at that gap, and any other thing that the tyre will hit if moved inwards at all.
You need a 2 or 3mm gap minimum.
Provided you have this now, then the thing that determines the total width is the tyre width.
If you had a 3.50x8 tyre (3.5 inches) and fitted a 4.5 inch wide tyre, then each side will be 1 inch wider. Adding 2 inches to your chair. :problem:
My 120 tyres are in mm. Thats about 4 and a three quarters wide in inches. Those would be a slightly SMALLER diameter, but not much. And 1.25 inches wider each side. So your chair will be 2.5 inches wider than it is now.
With 110/80 tyre it will be .87 inches wider each side. So add 1.75 inches to your existing width.
Postby expresso » 10 May 2018, 15:17
As it the tire rim sits right now on my chair - its as close as it can be to the motors - i mean its so close that i didnt think it would work but it does - the tires can not go in closer the motor any more.
If i understand you correctly BM - does this mean that if i used the rims from shirley with a hub adapter he may make for me - and use the same 3.50 x 8 tire on a 2.5 rim - this would make my chair even wider than it is right now at 26.5 inches ?
i dont mind if i have to use a different tire size - i just cant find any here that make it the same OD as a stock tire rim combo and same width of a 3.50 x 8 tire that i am using now -
since my tires have that small pinched look because of the smaller rim width - its not too bad really on my chair the look - but if the rim was just a bit wider - wouldnt it just make the tire sit flusher and more even without adding width to the overall chair ?
Someone here just did tires on his chair and extended his original two part rims - it came out very nice looking actually - i am not able to do that myself but the idea is to just make it fit better with the tire - and keep same width if its possible
take a look at these - big difference over a stock tire -
Postby expresso » 10 May 2018, 15:20
this is another user who just did his tires - using the same tires i have size etc,
but they sit flush on his rim because he added to the rim making it a wider rim - thats a great idea he did and worked perfect - i would think he needed longer screws now and maybe the bolts to hold the rim on the motor hub ? or maybe they were just enough - either way it came out nicely done -
Postby Burgerman » 10 May 2018, 15:37
No in both posts! I never mentioned rim widths. Only tyres. But a 3.50 tyre is already taller by too much. And fitting it on a wider rim means it will end up 2 to 3mm wider each side of the tyre. Knowing that, you just make the wheel adapter to move the wheel outboard by a couple of mm. So your chair will be only 1/4 inch wider overall. And the rims wont look good (too narrow, need to be on backwards, etc. All in all its a bad plan!
And you wont!
There isnt one.
The options are:
300x8 stock
350x8 taller that all the rest/wider
110/80-8 wider still and not wuite as tall.
120/70-8 widest, which works and looks best and is the closest to stock diameter from all these sizes.
Postby Burgerman » 10 May 2018, 15:43
download/file.php?id=8284&mode=view
110/80-8 on a wider rim.
Same as:
Postby expresso » 10 May 2018, 19:42
Ok - does this mean i am stuck with what i have and cant do any better ? if i want to keep the width the same -
on a 2.5 inch rim from shirley -
would this be the size tire i would need ?
120/70-8 widest, which works and looks best and is the closest to stock diameter from all these sizes. - this would make the chair wider ?
i mean if i can do 27 inch - that should make a difference much i dont think from 26.5 now -
looks like my options are limited here - -
Postby Burgerman » 10 May 2018, 20:07
1 single 120 tyre is 120mm wide. Thats almost 5 inches. Yours are 3.5 inches.
Your chair would gain 1.5 inches per side! So 3 inches wider than now.
Postby Burgerman » 10 May 2018, 20:09
Like this:
3.00 stock...
and 120/70
Postby Burgerman » 10 May 2018, 20:13
or...
3.00 stock...
and 120/70
Postby expresso » 10 May 2018, 20:20
ok then thats too wide for me -
i am wondering now is it worth it for me to get rims and adapters if there are no real good options for me - i though having the rims from shirley and adapter with some kind of offset would make it so i can use a tubeless tire on a rim just a bit wider than stock rim - 2.5 inch and not have it stick out any wider than it is now -
i wouldnt want to do all this work for nothing - so my options are basically use what i have now with tubes or thinner 300-8 tire with tube also to try to keep the OD the same but would be thinner - the goal was to have a nice width on the rubber . 3.50 seems decent but lower OD would be nice and on those nice Rims shirley gets
all for the sake of trying tubeless and nice rims - or else i have to stick with what i have now and be happy
Postby Burgerman » 10 May 2018, 20:29
In the case of the Salsa chair, here, its width specs are:
Overall Width:
600mm (12.5" wheels)
620mm (14" wheels)
So it started at 620, with a 10mm gap to motor. (Thats 24.40 inches)
So reducing the gap to 3mm, means overall width could be 14mm less than this. So when I fitted the 120 tyres/wheels, I reduced this to 3mm.
So now we have, 620mm less 14mm = 606 wide.
Less 76mm for the old tyres from the 606 width each side is: 454
+120 for new tyres each side, means the chairs new width is 694mm. Thats 27.3 inches.
Actually the 120 tyres are not quite 120 so a little less. Ends up at a tiny fraction over 27 inches.
Your chair starts out wider. So will end up too wide.
So we deduct
Postby Burgerman » 10 May 2018, 20:32
On the salsa chair, which is just 24 wide to start with, adding those rims makes sense. Because its already 27 wide across the arms with my cushion/arms etc. So the new 27.3 width is the same as the arms. The wheels dont actually stick out at all.
Postby expresso » 10 May 2018, 20:55
ok i see - my chair was i believe 25.5 wide from the start -
i guess the only tire is a 90/90 - 8 if they make that size - that would give me 3.5 wide tire but may be too much sidewall then - ?
bottom line i am stuck with what i have unless i want to make the chair wider ? i though having the correct rim size would make the tire just not looked as pinched and flatter - i believe 2.5 inch is correct for the 3.50 x 8 tire or similar
getting rims wont solve anything in my case ? or improve anything
Postby Burgerman » 10 May 2018, 23:12
2.75 should be OK.
But yes, unless you move the motors IN by the extra tyre width, you cannot go wider.
90 is wider though by a couple of mm! But slightly less tall.
76 is the same as a 3.00 tyre.
This is just 25.4 wide.
Because to fit 145mm or 5.5 inch wide tyres, I moved the motors in by 3 inches each side.
http://www.wheelchairdriver.com/images- ... mp-car.jpg
Postby expresso » 10 May 2018, 23:22
ok so your suggesting a 2.75 inch rim with a 90/90 - 8 inch tire ? that would work with no other modifications ? may just be a few mm wider than what it is now - ?
i was thinking 2.5 inch rim - shouldnt that work better to keep it at the same width ?
lets say - i got a 2.75inch rim from shirley - with the hub adapter and a 90/90 - 8 tire - what would the outcome be more or less ?
i just need it to work with no modifications on my end - - other than adjusting the fender - thats fine - but cant move the motors etc, -
another thing - the screws on the hub - that the tire bolts down to - those dont need to be touched ?
Postby Burgerman » 10 May 2018, 23:42
I dont see a good way to fit the narrow rims at all. Theres no room for any adapter, the centre nut will be sticking out, it will all look a bodge...
A 90/90 tyre is 3.55 wide.
And is 90% of 3.55 tall. So overall diameter is 81mm x2 sidewall. So (81 x 2 div by 25.4 to give incheas, plus 8 rim, gives 14.37 diameter
The 350 is 3.50 wide, and 3.5 + 3.5 + 8 = 15 diameter.
The 300 stock tyre is 3 wide, 3 sidewalls, and 8 rim so 14 diameter.
Postby Burgerman » 10 May 2018, 23:47
I may add, that while its a size that is manufactured, its rare. I never saw one.
Postby expresso » 11 May 2018, 03:27
Ok so the best tire would be a 90/90 closet to stock just wider and would work on a 2.5 inch rims. ? But may be hard to find if at all. Maybe I am making a big deal for nothing and just stay with my stock rims tires ? I will try look for that size just to see what's out there curious. The rims would have looked nice maybe more trouble than itz worth. U don't think it's worth having shirly do the work and get rims ?
Postby Burgerman » 11 May 2018, 09:13
Not if you have to fit them backwards and have a nut sticking out of the middle. I wouldnt.
Postby expresso » 11 May 2018, 15:46
yeah - i wouldnt want them backwards etc, - i guess i put this to rest then - leave it alone the way it is - unless its broken i wont try to fix it - - the other user who made his stocks rims wider by adding a spacer between two rim halfs - he did a great job - that can be something i can try just to see - i have spare rims -
but i wont be able to do it myself - what would it take to do what he did - maybe half inch wider ? - that would make the tire fit nicer -
Postby Burgerman » 11 May 2018, 16:07
Not seen your wheel but maybe its easy. Maybe not.
Postby hobie1dog » 11 May 2018, 23:32
While we are talking 636 wheels and tires, my same stock setup measures 25 3/4" wide. I would love to get a tubeless tire that would be slightly taller and wider. I like the look of the 120/70 tires that were pictured. Are there wider wheels with more offset, which can be bolted to the stock hubs? I don't mind adding extra width to the chair.
Invacare M61
hobie1dog
Postby Burgerman » 11 May 2018, 23:43
None I ever found. However if you cant make an adapter, shirley_hkg can do it aparently.
Postby expresso » 12 May 2018, 00:16
by adding an adapter - wouldnt that alone make the wheel about a inch wider ?
in that case a 2.5 inch rim or 2.75 inch rim with a bit wider tire would work - - at what cost to the width of the chair ? 28 inch wide ?
Postby expresso » 12 May 2018, 00:21
hobie1dog wrote:While we are talking 636 wheels and tires, my same stock setup measures 25 3/4" wide. I would love to get a tubeless tire that would be slightly taller and wider. I like the look of the 120/70 tires that were pictured. Are there wider wheels with more offset, which can be bolted to the stock hubs? I don't mind adding extra width to the chair.
if you end up doing it - post some pics - i like the wide tires - but want to keep it at a min. if i can - your chair is the same as mines - size wise etc,
Postby hobie1dog » 12 May 2018, 00:32
Burgerman wrote:None I ever found. However if you cant make an adapter, shirley_hkg can do it aparently.
I wonder if he can post up a drawing for us that I could take to a machine shop?
Invacare M61
hobie1dog
Postby Burgerman » 12 May 2018, 01:52
I have no drawing as such, but heres what you need to draw or make. viewtopic.php?f=2&t=7455&start=140#p114267
Scroll/read.
I ordered some laser cut alloy disks. And just used a pillar drill in my bedroom.
Postby expresso » 12 May 2018, 22:00
nice - this may not be the best thing for me to take on - even with shirley making the hub adapter and getting the rims - it may not end up as nice or too wide i believe afterwards - thanks for the facts and whats needed to get it done -
i recall shirley added the rims to his chair etc, but it didnt add any width over the 3.50 x 8 tire he was using before ? i think he went to 10 inch rims - but seems the same width from some pictures i seen a while back
Users browsing this forum: No registered users and 75 guests
