If i understand you correctly BM - does this mean that if i used the rims from shirley with a hub adapter he may make for me - and use the same 3.50 x 8 tire on a 2.5 rim - this would make my chair even wider than it is right now at 26.5 inches ?
i dont mind if i have to use a different tire size - i just cant find any here that make it the same OD as a stock tire rim combo and same width of a 3.50 x 8 tire that i am using now -
hobie1dog wrote:While we are talking 636 wheels and tires, my same stock setup measures 25 3/4" wide. I would love to get a tubeless tire that would be slightly taller and wider. I like the look of the 120/70 tires that were pictured. Are there wider wheels with more offset, which can be bolted to the stock hubs? I don't mind adding extra width to the chair.
Burgerman wrote:None I ever found. However if you cant make an adapter, shirley_hkg can do it aparently.
Users browsing this forum: No registered users and 431 guests
