PL8 is an excellent battery charger.
What to buy to be able to charge gel batteries?
What cables and accessories do I have to buy?
You need to clarify a bit!
http://www.store.revolectrix.com/Products/Cellpro-PowerLab-8-EC5-version
SANE price. 225 dollars. 190 euros. Plus shipping.
Burgerman wrote:Here you go...
But I cannot limit this to max 12A. So if you choose higher, you will melt something.
Burgerman wrote:God knows, because I never found 2 mobility chargers that did the same thing.
But IF it charged at the correct voltage for gel, then that would be too low just, to allow the balance on the BMS to work. Unless one cell was high by a margin. And, it would be 8A which means it will take 50 percent extra charge time, and it will likely terminate too soon at about 1A and go to float, which is too low for balance or charge. So likely safe but we cant know it will do that!
E.G. the new salsa chairs charger I have, has no termination point based on current at all, other than an 8 hour cv timer. And is 29.0v. That would do your lithium no good.
sin85 wrote:but i will use the bms for charging only.
i realise that it would take long time to charge @12A but i will probably never go quite so low as 90%. this set up is temporary and simplified for middle aged uneducated carers that have problems.
it is filon futur
https://www.ieb.de/en/products/filon-fu ... -08-08.pdf
sin85
Users browsing this forum: Burgerman, iansp, Jay_x, jefferso, MagicJin and 104 guests
