shirley_hkg wrote:Your PSUs are a bit different . Factory manu locked .
Operation tips :
Burgerman wrote:2, lock menu (not sure what that does?)
If unlocked , we can enter factory menu by press-and-hold 3 seconds during NO OUTPUT stage . Its locked and we could via it to shut down psu only .
3, auto output at power up (not sure what that does either yet?)
Otherwise , amp LED displays OFF , and we have to press enter to resume output .
4, auto power up at MAIN on (not sure what that does? Again!)
Otherwise we have to press once to start the PSU.then .
5, a 3-stage charger; with adjustable
steves1977uk wrote:How do I set the Over volts limit to 30v? When I enter that menu, I can only set a max value of 3.0 on both the volts and amps?
steves1977uk wrote:Nice work BM! My PL8 shows 29.35v unloaded when the PSU is set to 30v. Does my PSU need calibrating?
PL8 isn't that accurate after all.
It also makes the fans run faster. Instantly since they cant get any air. But airflow is very restricted. It does quieten the thing though. Till it gets hotter!Burgerman wrote:Fans.
So... I have fitted my new free flow one, and added a resistor (speed reducing plug in one for a pc) to each fan. Now its quieter and has better air flow. Just in case you are sleeping next to it.
Burgerman wrote:Using
I reset the voltage to 14.6 to get 14.7 for charging.
Users browsing this forum: emilevirus, shirley_hkg, Superchunk and 71 guests
