Burgerman wrote:Yes a 100/200A heavy diode in series with the lifepo4 cable saves the lithium, and uses more lead. So you dont just lean on the add-on most of the time. Also means the battery meter will make more sense.
Say 2x these in parallel, would do it. They will drop .7V approx, so your lithium will be 25.6 less .7 = 24.9V most of the day.
https://www.ebay.com/p/50-X-Vishay-Powe ... 1021668224
Burgerman wrote:In one end, out the other!
Burgerman wrote:This also means that any regeneration current will be blocked, so it will all go into the lead. A diode is like a one way valve. Like a tyre valve. Electricity can only go one way. In the soldered part, out of the bolt / thread (ring terminal). But it also needs a heat sink.
But it loses .6 to .7 of a volt. So we will be using its normal disadvantage to our advantage.
Burgerman wrote:15A max? He already blew a fuse 3x that size! And I would expect 100A or so to flow at times for short period.
shirley_hkg wrote:Haven't replied me about shipping to US yet .
i never understand why they put 70A breakers on chairs with 100A controllers etc, - dosnt make sense to me but still they work fine makes me thing how long or often are we using up 100A or 120A on our chairs -
Users browsing this forum: emilevirus, snaker and 455 guests
