expresso wrote:If i understand correctly - 90ah Cell rated at 2C - that means it will do constant discharge 180A - maybe more peak - but forget peak for now -
if you used 16 of those 90ah Cells at 2C rated - then it a bit more than borderline min. for our chairs at 360A
if this is correct - you can use a 2C cell if 90ah and using 16 of them ? this would be OK ?
Now of course if a 90ah Cell at 3C is used - would be much better at 270A for 90ah Cell at 3C
and of course you would use 16 Cells giving 180ah of battery at 540A discharge rate ? is that correct ?
i am curious to know because i do find many 90ah Cells but are 2C rated - which is still ok if the above figures and my understanding is correct .
i founds some 90ah Cells at 5C - which would be great but too tall at 280mm -
expresso wrote:the new cells i just purchased - if they are not lying to me about the specs - its 5C - 60ah Cells - thats great -
i really wont know anyway - i will make it - and use as an ADD ON and thats it - i am sure they will give me some more range and last many years - this chair wont be used as much -
i may have to make connectors with wires - dont think i am getting any - i asked for them but they said they will try - so means they dont have them and may not get -
elryko1992 wrote:expresso wrote:the new cells i just purchased - if they are not lying to me about the specs - its 5C - 60ah Cells - thats great -
Expresso when you build your new cells make photo to see the steps if you want like a tutoriali want to see, when my MK is gone i want to buy this cells 60AH.
Burgerman wrote:Connectors are easy. Just loops of cable with a ring terminal at each end. 7 needed.
shirley_hkg wrote:shirley_hkg wrote:Haven't replied me about shipping to US yet .
Shipping to UK , USA , AUSTRALIA are OK. Same rates .
expresso wrote:elryko1992 wrote:expresso wrote:the new cells i just purchased - if they are not lying to me about the specs - its 5C - 60ah Cells - thats great -
Sure no problem - i was thinking of that also - take it slow and try to make it simple steps - with pictures - will try to make it simple to understand and easy to follow with pictures step by step -
if you used this 60ah Cell for the whole chair - you would have 120Ah pack - 16 of them - the seller has been helpful and making an effort to make me the connectors - hopefully they work out - i should expect this order sometime in July if all goes well - free shipping takes up to 36 days - maybe sooner - they havnt shipped yet
shirley_hkg wrote: You must be prepared and willing to take a risk . You are gonna be the first crab-eater .![]()
Gnomatic wrote:shirley let me know when you are willing to purchase and ship some battery cells. I will pay.![]()
Furio wrote:Hi all,
Today completed assembly of 8 nos. 120Ah cells into a pack.I followed snaker's mode of "Rice pack",though not so perfect.
Used 1mm silicone sheet (cheap and quality in India)and glass fiber tape for cricket bats.
https://www.zenithrubberstore.com/shop/ ... ansculent/
I would like BM to give a preset for charging the set.![]()
Furio.
either. So its always best to just keep away from each end.
Burgerman wrote:With ead, you can take more than the batteries capacity from it. Ie you can go past 100Ah from a 100Ah battery. Its voltage drops to 9 or maybe 6 volts. That does a little damage but you can recharge and get back maybe 97% of what you had before.
With lithium you cause a lot of damage going below 2.5V. Or above 3.65V per cell. Theres no actual figure. They dont much like below about 2.7, or above about 3.5V. And dropping to 2.0V under load once or twice may not hurt if youeither. So its always best to just keep away from each end.
If you are a manufacturer you will charge to 3.65V, and discharge to 2V to measure ultimate capacity. But YOU should not! Althought thats exactly what a BMS does. Or much worse!
Only the Combined Chair preset is set at 3.525V because of the Lead -
@£32
Users browsing this forum: jehan, shirley_hkg and 537 guests
