LROBBINS wrote:U.S. wall plugs do not have fuses, nor (as far as I know) do wall plugs anywhere except in GB.
Efficiency varies depending on the volts in, and the volts out, and the current out.
User adjustable? Yes thats the point.
The problem is that most users wouldnt know how to configure it, as it takes knowledge.
You will need some ring terminals, to connect more securely at the rear, some cable, and anderson connectors etc to charge above 12A.
And you need care.
martin007 wrote:
The Fluke multimeter will help me.
Users browsing this forum: Bing [Bot] and 171 guests
