Burgerman wrote:First try to forget about prehistoric confusing inches. The rest of the world gave up on those when I was at school.
The connectors will be 8, 10, 12 mm since this was made in china. It will have M8, M10, M12 etc threads/nuts. At a guess, it may be bigger? Cant tell from a photo. So measure them.
Use cable the same size as the cable you used on the chairs previous addon or a little bigger. Again I dont understand your analog sizes. So same as you did before on the old addon connecting cables, but between cells. Preferably silicone as its more flexible and your terminals will be too close so the cables will be a U shaped loop.
Burgerman wrote:2 to 3mm or 3/32 or 1/8th inch in analog ABS plastic or polyethlene sheet at the bottom.
snaker wrote:Expresso, check the bottom of each cell first. As my terrible experience, the bottom might not be full wrapped. If so, fill it by electrical tapes (or something good for insulation).
Burgerman wrote:Use multimeter. Check voltage from case bottom to each terminal. See if either is connected. I think it will be.
You need 9 of these for balance wires.
https://www.ebay.co.uk/itm/RED-10mm-INS ... Swl-BZql4L
And 16 of these
https://www.ebay.co.uk/itm/5-x-10mm-Cop ... 0005.m1851
And some black heatshrink.
And one of these cheap lighters. In the shops at 1.99 and refilable. I got 3.
https://www.amazon.co.uk/Refillable-Win ... urbo+large
Burgerman wrote:https://www.ebay.com/itm/Heavy-Wall-Copper-Cable-Lugs-Ring-Terminals-Various-AWG-Sizes-Welding-Battery/380957309836?var=650293273565&hash=item58b2d33b8c:m:m3r6PK3UbZX9oaH6n-xNhXQ
With these you dont need to solder of crimped correctly. But you will be bankrupt.
Burgerman wrote:Box looks a bit fragile and small. Maybe you can find a close fitting rectangular rucksack type of bag. And just use duct tape on the pack or heat shrink.
Burgerman wrote:Cut those sticky out push handles off. And use two rubber caps.
https://ae01.alicdn.com/kf/HTB1OWm1QFXX ... 40x640.jpg
Users browsing this forum: Bing [Bot], JMGarage and 80 guests
