Sinopoly Cells - Info -
Re: Sinopoly Cells - Info -
Postby Burgerman » 06 Jul 2018, 23:17
And when I get off this bed again in 2? weeks I will measure the width if the salsa chairs battery compartment sat 4 feet away.
Unless someone can do this for me easily? Anyone got one in bits that understands mm properly??
Postby Gnomatic » 07 Jul 2018, 01:30
They are each 130 wide, So 2 is the same as an MK. the ones you link to are 135 wide. So need to be turned around. And then you get 150Ah rather than 210Ah with wasted space on 4 sides.
If I ran two columns side by side and eight across it would be CLOSE, that wasn't how I was picturing orienting them. The 8 cells in the columns would be 11.65" or ~296mm, My battery area is about 13.66" wide side to side, or 347mm. So would fit easily with a couple inches to spare. Plenty for insulation, ballast ect.
The tricky part with my battery area is front to back. it has only 10.25", or a hair over 260mm. Not enough room for adequate insulation. I could mod my battery area with out a TON of hassle to give myself room for 10.75" front to back, in which case there'd be room for insulation. 210Ah, that would be IN-FREAKING-SANE!!! I could get two weels+ on a single charge in the winter LOL! But would take some work. I can't read Chinese but looks like those 105Ah cells are 195mm tall at the shoulder and 200mm to the terminal. Same as those 75Ah cells I believe.
Honestly, my 90A Headway pack I've been using since last summer has been awesome. Rarely leaves me wanting more, though it does occasionally happen that I know to stop sooner than I'd like. Either way, beats the hell out of lead bricks. So for me, jumping to a 150Ah pack would be a huge 60% more capacity jump. And extremely easy to fit.
Postby Burgerman » 07 Jul 2018, 02:06
A hair over 260 is all you need. An extra 3.6mm to be exact, or in analog 1/8th inch. That allows a plastic or polyethelene 1mm sheet (credit card thickness and a bit) in the 3 places its required. One between the two centre cells. And one down each side. So how much is that hair EXACTLY? If its 3.6mm you are good to go. To give you an idea, on a typical 100dpi PC screen you need this much extra __ and that is 5mm! You need just 3.6!
3 bits 1mm thick, x 200 tall, and 305mm long. Thats one down the centre, one each side, taped or glued on with contact adhesive.
Then...
2 bits 1mm thick, x 200 tall 263.6 wide. For the other two outer edges.
Then... As cell dividers, 14 bits 1mm thick that are 200 tall 130mm wide.
Then a BOTTOM that is 2mm thick, and 306 x 263.6mm to sit the whole thing on.
A smear of silicone RTV or contact adhesive to attach the sides, seperators etc. Then tape with duct tape or fibreglass tape all the outer seams or corners just in case. You will then have one solid brick. 200 tall, 307mm long, 263.6 wide. Or change measuremets a little and have 2x 210Ah 12V ones. Or two 105Ah 24v ones...
Heres why I think you will not have an issue. https://www.tayna.co.uk/leisure-batteri ... x/xdc24mf/
Some group 24 batteries are a few mm smaller or larger than 260mm. 252 up to 266 seem quite easy to find. So they must fit.
Postby shirley_hkg » 07 Jul 2018, 02:35
Burgerman wrote:MEANING that you can fit 210Ah in place of lead, provided that you have JUST 4MM mm extra width available over a grp24 battery.
The math:
Cells are in mm:
130.3
37
200
37 x 8 = 296
37 x 4 = 148
We have a 240mm tall box. With 260 (or more) x 340 (or more although this way not an issue)
Arranged as
2 side by side is 260.6 (plus 3mm insulation from 1mm sheet so 263.6 total)
8 deep gives 296 (plus 9mm insulation so 305 total)
So with careful measuring it might just fit 16 cells.
210Ah in place of 74 (45 to 50 usable) So 5 to 6 times stock range. For £512
HOW MUCH will this cost to ship to UK in pounds for 16 cells and a huge 210Ah pack?
Thanks!
shirley_hkg wrote: goodpost Air freight : £6.75 / kg to UK ; custom fee included . No more extra at all . That's what I've been told. :worship
EVE-LF90 , Rated --- 3C (5C max) ; IR @ 0.5mΩ .
90Ah cell , 2017/8/31 NOS @£27.50 :clap
* * * * unknow batch NOS @£18.80 :dance
EVE-LF105 105Ah * * * * 2018 batch NOS @£32.00 :dance
Any guinea pig ? ? ? drunk2
Postby Burgerman » 07 Jul 2018, 09:14
But how much will a package weigh all boxed up? 105Ah cells. x 16 plus packaging etc.
Postby Burgerman » 07 Jul 2018, 09:21
What about slo boat?
Is it possible?
Because the 6.75 kg is more expensive than the cells. It may be cheaper to send my ex gf to hong kong or china to carry back in her handbag :cussing
Postby shirley_hkg » 07 Jul 2018, 10:17
Cell weights 1980g.
16 of them will be 35Kg , including packings.
Post office won't take batteries . :fencing
Postby Burgerman » 07 Jul 2018, 10:40
237 shipping + 16 105Ah cells = 750 uk pounds for a 210Ah pack. Still good price! I just need a salsa accurate measurement.
Postby Burgerman » 07 Jul 2018, 10:52
237 shipping + 16 105Ah cells = 750 uk pounds for a 210Ah pack. Still good price! I just need a salsa accurate measurement. And will then order.
So lets see.
Salsa claimed range is 27 miles. From a 70Ah grp 24 at best you get to use 45Ah.
So with 210Ah, and use 200 for safety, from the lithium, you get around 4.2x better range.
27 iso standard miles, becomes: multiplied by the 4.2 = 113 miles. Or 182km.
So for £500 you get 2x MK, and 1 years use, and 27 miles.
For £750 delivered from china, you get 113 miles and a 6 to 10 year lifespan, fast charging in a few hours, and save 50lb of weight.
Postby shirley_hkg » 07 Jul 2018, 12:05
On second thought , 105Ah cells are rare and not heard of any review . Not worthwhile .
90Ah one is better .
Postby Burgerman » 07 Jul 2018, 13:06
Why? I like the idea of over 200Ah :cussing
Postby shirley_hkg » 07 Jul 2018, 13:40
Too little information about this cell and seller .
The safe way to go for it, if you insist , is to buy from dealer direct . That would be expensive and couldn't get the best value for money . Isn't it the the only reason to buy Chinese products ? banghead
Postby Gnomatic » 07 Jul 2018, 16:19
Here's a pic of my battery case.
I got ~10.25" or 261mm. So I'm pretty sure I'd need to mod it a bit to to fit those 105Ah(or 90Ah) cells. I got about 1/2" I could extend that rear panel back before it would be close to interfering with the rear casters. That would give me 10.75" and the mod wouldn't be too difficult. But still, its more work.
The 75Ah cells on the other hand, I could fit 16 easy. 16 of those is still a 150Ah pack. And no mod required. 210Ah is great, but realistically, how much real world day to day benefit would a pack like that be over a cheaper 150Ah pack. I don't think I could use up 150Ah in a single day if I tried. More likely a charge would last me two or three days in most cases in the summer.
Postby Burgerman » 07 Jul 2018, 18:00
Throw away that analog stick at once! :fencing
You need 260 plus 2 mm for a perfect fit. 1 cell, 2x 1mm sheet. To fit 8S. Presumably there are two battery compartments? And no protruding bolts.
May I suggest some 1 inch x 1 inch metal bars and a jack.
Postby Gnomatic » 07 Jul 2018, 19:00
Burgerman wrote:Throw away that analog stick at once! :fencing
:lol:
Burgerman wrote:Presumably there are two battery compartments? And no protruding bolts.
No, one big battery compartment, holds two G24 MK gel. And some protruding bolts as seen in pick as seen in pic.. This made fitting my 90Ah headyway pack a bit tricky. I lined the entire thing with a layer of 1/16" rubber rubber, and a layer of plastic drawer liner before installing my pack.
With the 75Ah cells, I like the extra space around the cells in my battery box. I could even put the pack in its own custom enclosure and set it inside my battery area. Plenty of room in there on all sides for that. Only way to do the same with the 105Ah cells would be to mod my chair to fit, Do you not think a 150Ah pack is enough with those 75Ah cells?
Burgerman wrote:May I suggest some 1 inch x 1 inch metal bars and a jack.
For?
Postby Burgerman » 07 Jul 2018, 20:44
You only need 2mm Just over 1/16th of an inch in analog. You can make the battery compartment that tiny bit bigger. Jack it apart.
Postby Gnomatic » 07 Jul 2018, 22:38
Burgerman wrote:You can make the battery compartment that tiny bit bigger. Jack it apart.
The rear of the battery box comes off with 4 bolts. I'd need some type of spacer, about 1/2" of room it could be moved back before the panel would begin to interfere with the rear caster pivot space. Maybe my nephew can make something with his 3d printer?
Postby Burgerman » 07 Jul 2018, 22:47
Washers. They are 1mm thick!
Postby Furio » 12 Jul 2018, 10:54
This is the fag end of 120Ah battery discharge. The voltage is all over the place. :shh: After charging to full, I initially discharged 105Ah through a Turnigy wattmeter to 24v truck halogen lamps.Then connected to pl8 and discharged the remaing 7.8 Ah till charger stopped on cell #6 voltage.
Also the charging data after the above discharge. :shh: :problem:
BM's opinion please. :argument
Furio
Postby Burgerman » 12 Jul 2018, 18:01
They are all ended really thopugh. Maybe only a percent or so between all of them. They wont all be empty at the same moment. You are only looking at the very ending. You dont see this with headway cells because there are a lot of cells. So that they all average out. As you discharge in use, the cell to keep an eye on will be the one here that drops lowest first.
Postby hobie1dog » 13 Jul 2018, 14:26
Just read all 14 pages of the thread, thanks to all who contributed. I like this style of cell, a little expensive though .
Invacare M61
hobie1dog
Postby shirley_hkg » 14 Jul 2018, 06:18
Another cheap cell , nos 80Ah @£17.50 .
Famous brand , CATL with super low IR 0.37mΩ can survive high C-rate discharge .
:clap:
Postby Burgerman » 14 Jul 2018, 08:02
Allwws 160Ah if those cells are any good. But wastes 70mm in one direction and about 20mm in the other, Unused.
Postby shirley_hkg » 14 Jul 2018, 10:10
shirley_hkg wrote: Found this EVE-LF105 , same size as the 90A counterpart , but 105Ah . butred @£32
viewtopic.php?f=2&t=7766&start=220
EVE-LF105 , I would only recommand BRAND NEW cell , which is not cheap @£81.00 . :bs
LF90 seems the best pick , nos @£25.00
Postby Burgerman » 14 Jul 2018, 11:34
They are not brand new?
Only inrerested in brand new. Anything else = problems...
Unknown history, calender life part used up...
Postby shirley_hkg » 14 Jul 2018, 11:56
May be I shall give it a try .
Have to get rid of my 135Ah 40152 headway pack first .
Postby hobie1dog » 17 Jul 2018, 05:39
shirley_hkg wrote:[b][size=200][color=#400000]Another cheap cell , nos 80Ah @£17.50 .
17.50x16 cells= £280 pounds which converts to 371.00 dollars
Add another $280.00 for a PL-8 charger
$100.00 in connectors, cables, heat shrink
750.00 or so for 160ah conversion?
Invacare M61
hobie1dog
Postby Burgerman » 17 Jul 2018, 08:02
If they will fit your battery area.
Remember you get approx 40 to 45Ah MAXIMUM from healthy lead, and often a fair bit less. And they dont stay healthy for long.
So 160Ah of lighter lithium, is a fuel tank, and fill up, that is literally 4x bigger. So if you were filling your van its like filling it with 4x the gas. So while it looks expensive compared to lead its not. That price is actually cheap. Its the same thing as buying 8 MK lead batteries!
Cell quality? Ask Shirley. You may have US customs charges though. I never have from Hong Kong. Or china though but you never know.
Postby expresso » 19 Jul 2018, 01:34
shirley_hkg wrote:Another cheap cell , nos 80Ah @£17.50 .
:clap:
Shirley - i would be interested in this kind of Cells - 8 of them if you up to it ? i am not in a rush this time - if you come across something good in this size is what i need - if its less than 220 high - even better but the 28mm works for another ADD ON -
Users browsing this forum: fishinjunky, swalker, Yennek and 529 guests
