Burgerman wrote:It will make no difference. You can prove that by swapping a few around.
Wouldnt worry, its still a decent 50Ah addon.
Wont make ANY difference iif they were soldered. And tight.i see - didnt think of swapping them to see - I feel my connectors werent the best fit - making me think if it had a better fit - less IR - maybe could make that difference ?
fter i changed the balance cable - the order which i had it - i monitored it for a moment
Burgerman wrote:Throw away the lock washers. They make bad connection. Just a plain washer under the nut.
Gnomatic wrote:expresso those charge graphs look improved already, Maybe do another discharge (a single session to 2,9v) and charge again. Maybe things tighten up even more.
Burgerman wrote:It will be the same. You are just seeing the voltage drop after charge ends... Cell 3 drops slowest.
But a full curve without break in the middle will look better and they will appear closer together. But same Ah capacity about 47. Or 1 either way.
You get more at a higher discharge rate, because ithium improves with temperature and discharging faster warms them up. But only by 2 or 3Ah. And a little more if you discharge lower. But dont!
All thats happened is the chinese are using special chinese Ah for marketing purposes. (Or possibly older stock 60Ah cells. Or used.) Tell me. Is the case negative, positive, or floating and disconnected?
Users browsing this forum: Bubbernator and 512 guests
