My right stick has a throttle, for helis, no ratchet. And I drive with main steer axis on that right stick, (aileron in a 4 axis heli or aircraft) And use the left stick which spring centres on all axis, for forward and reverse. So split stick.
Kolaf's video shows that he is using the LEFT throttle channel WITH RATCHET for forwards/reverse .
Just in case you are not aware of this, the chair FRAME should never have a direct (low impedance) connection to ground, so do make sure that your ground interconnects don't also connect to the frame (except by a capacitor if you want to reduce noise).I have connect the ground from the chair and from my power supply.
Users browsing this forum: Burgerman, emilevirus, yeshelp and 539 guests
