Burgerman wrote:We saw those before. Was waiting to see if anyone has tested them. But I like round numbers.
Ooh sorry i didn't realise.
A nice fit in the salsa though.
I might take the plunge after xmas.
Burgerman wrote:0.3 x 20mm wide is the same as a 6mm sq mm wire.
Which is what I would likely use for an addon anyway. But if you can use 2 for each, then do so. Since 6mm2 is good for only 60A.
snaker wrote:Mine are 2mm thick
Burgerman wrote:You have 60Ah batteries now?
So about 35 to 40 usable at best. So a real 200Ah will allow you to have 5x the range. Since lithium dont shrink!
Claimed range 26 miles? If you only get a real 18 mile range outdoors, then this will give you 5x more, so 90 miles.
May be a lot more since expresso gets about 45 miles from a 90Ah battery with some left, and thats on an 8mph greedy set of motors otherwise identical motors.
or maybe something like this would work better ? they seem to be the same length - less width but seem thicker from the picture
or 5.2 mm thickPackage Dimensions 7.5 x 5 x 0.2 inches
Scooterman wrote:Out of curiosity if one was going to build two physically separated 12v lithium batteries with prismatic cells, is this how they'd be arranged? I've not drawn the balance cables yet as my learning hasn't yet reached that level.
EDIT: On hindsight if say the polarity of the 4 cells in the LH bank were reversed then it would allow for a shorter and neater end link cable, or something like that. I need some more kitchen roll to make another diagram.
22 Mil/16 Ounce Copper (.0216") 24 gauge: 16 ounce copper sheeting is a heavy weight copper often referred to as "roofing copper" or "roofing flashing." It weighs approximately 1 pound per square foot.
expresso wrote:
my pack is not 90ahits 105ah inside the chair - i could get 45 miles from there - 40 for sure - motors are 8.5 standard on that chair - with added volts and larger tires - lithium - i get 10 mph - and now i have a 45ah ADD ON also - this chair is all headway cells both inside and ADD ON. - not in rush to change them either.
these new Cells i am using - we just dont know how good they are long run - or even short run for that matter -
Users browsing this forum: Bing [Bot], Burgerman and 447 guests
