jefferso wrote:I have some extra 2mm diameter stranded cable, but for 20 or 30A, I'd need more robust cable, correct?
shirley_hkg wrote: Simply use 2 stranded pairs and you'll have 4m㎡ cables .
Use what you have .
Burgerman wrote:But a single silicone diode or 2x shottky will. Which I cant spell, would give either .7 or .5V APPROX drop depending on diode / load/curve you choose. All depending on what you need to do. The reverse diode should always be a single low drop one of course.
jefferso wrote:(26 May 2018, Re: To Buy a PL8 - Accessories, attachment: "Lead MK GEL 12A Max With XLR plg.PS8.zip")
viewtopic.php?f=2&t=7925&start=30#p119575
jefferso wrote:The one on the side of the chair is much closer to the batteries and has more substantial cables. Right now, when I'm charging at 12A with the PL8, the XLR plug and cable do not seem to get warm at all.
flagman1776 wrote:If you want to fast charge your chair with your PL8, why not install an Anderson SB 50 socket direct wired to your batteries.
Though with MK Gel batteries, I'd have to be pretty recently charged to offer to help someone start their vehicle.
Users browsing this forum: Burgerman, Kande_ian, MagicJin, sergey0, shirley_hkg and 161 guests
