shirley_hkg wrote:That may be complicated for me.![]()
I was about to make you the female D-sub of the battery end. It has 2 holes , that you can bolt it to a bracket .
Simply secure a mounting plate to the plastic shroud to accept the D-sub .
Unbolt two screws and you'll leave the complete harness behind .
Burgerman wrote:Actually the 8S extensions are low quality, better to get the Celpro ones ones if you can.
http://www.store.revolectrix.com/Produc ... sion-Cable
Or 2 4S ones if you have 2 12V batteries seperately.
Silver coated 0.75mm audio grade one to overcome long resistance .
Burgerman wrote:20A discharge. What on earth did you use to discharge 85Ah into? ..
Users browsing this forum: sergey0 and 319 guests
