Burgerman wrote:I usually charge at around 1/4 the capacity. So 25A for a 100Ah pack. If you want faster, feel free. But within reason. LiFePO4 is happier charged at around the 3 to 4 hour rate long term. If you charge slower than this then thats not much of a problem, but it means more time and its not necassary to charge this slow.
Termination current. If the pack is high C rate, and well balanced, then a 300th or 330th termination poing works well. So that would be say 300mA on a 100Ah pack. If the thing takes a long time to balance, and to hold voltage evenly after charge, then reduce that to 500th or 750th of capacity. So it stays at CV longer. A 4 hour CV timer is OK on a pack that balances easily. An 8 hour limit is too long, but may be needed to balance an out of balance pack, or much longer. So initially this should be set to off or never ending on a new built pack.
Theres no correct settings, only the best at the time. Like once the pack is in service and balanced well, then reducing charge votage to 3.550V will extend service life a bit.
shirley_hkg wrote: They are stored for a year or two .
I will charge @20A max , at least for the first few cycles .
Burgerman wrote:Dont use it. It increases current by x amount but leaves termination the same. Designed by an idiot.
Burgerman wrote:What does CV achieve?
Think about a battery as a resistor. Because it is also that!
If you take any battery at a low voltage. Say a LEAD battery, its all the same. Its dead, flat, exhausted at 11V. If you set a power supply to say 300A and 14.4V max, and connect the battery, in 2 seconds it reaches that CV voltage. Is it charged?
Obviously no! Take away the power, and the voltage drops back to 11V after say 8 hours. And its now 1% charged...
If you LEAVE it at that 300A CV for a while it will still be at 14.4V and the amps will gradually tail off. And become lower and lower. Eventually it reaches almost zero Amps. Now, it has soaked up that power. So now when you release the charger cables, and wait, it will fall back to the FULLY CHARGED voltage of 13.15V. This takes 8 hours approx on a lead battery at CV.
Lithium has a much lower resistance and zero Peukert to speak of. So it can be fully charged in as little as 3 mins CV for LiPo, 20 to 40 mins Lithium ion, and about 1 to 2 hours for LiFePO4. But with lithium theres a further complication.
We.
Burgerman wrote:We use 8 in series. So we must balance!!! So the FIRST of those 8 that reaches CV starts its soak time sooner, its absorption time, sooner than the last cell to reach CV. This is why its important to balance fast, to try to make sure all cells spend a similar time at CV. If you spend say 1 hour balancing, then the full cell spends 1 hour extra at CV. So it is "more full" than the others when charge ends and its voltage drops off less after charge ends. So if your lithium pack wasnt well balanced, or if balance current is too low, then you need to add more CV time... To ensure ALL cells get full. By lowering termination current.
Burgerman wrote:The bit marked balance is the CC stage where voltage is rising. Balance starts about 3.5V and continues to the end.
Users browsing this forum: Burgerman and 459 guests
