Postby Gnomatic » 28 Oct 2018, 21:02
QR Scan app on my phone got it straight away.
https://item.taobao.com/item.htm?id=199 ... 09f542c59d
Looks to decent and is certainly affordable.
Postby snaker » 29 Oct 2018, 01:22
shirley_hkg wrote: Scan the QR Code .
Thank Shirley.
Postby shirley_hkg » 01 Nov 2018, 11:31
No wonder it took so long .
Postby Gnomatic » 01 Nov 2018, 16:53
Your toy hits the road . :biker . . . :bravo :dirtbike
Already in the US. Definitely not by Slo boat!
Tracking says its in Chicago, being "processed" by US customs. czy
Postby Burgerman » 01 Nov 2018, 18:44
They have it in bits scratching heads trying to figure out what it is.
Postby Gnomatic » 01 Nov 2018, 20:12
That is my concern, probably using a :hammer
Postby Burgerman » 02 Nov 2018, 02:40
You mean checked out by a spanner with a hammer.
Seriously if they are not sure if its some part for a nuclear weapon or something then they WILL investigate it.
Which reminds me. This is a seriously interesting vid of 2 guys getting into a dis-used abandoned nuclear power plant 20 years after it was abandoned. Get your pop corn, 40 mins of fun. Theres still a few lights on, and the place is still connected to the grid, with about 750,000 volts supply... Hence all the buzzing. They dont get it. Lights left on for 20 years and a few still working! These guys are mad.
youtu.be/ONEm1ph3MP4
Postby cavorite » 02 Nov 2018, 06:50
Considering getting one of these, but noise is a factor. Using as an XLR charger (12A max), with Odyssey PC1200s. How noisy will this be, and what things can be done to quiet it?
cavorite
Postby shirley_hkg » 02 Nov 2018, 08:58
Fans run high during soaking . Doesn't suit you .
Postby Burgerman » 02 Nov 2018, 10:20
Go to computer part supplier like www.overclockers.co.uk , and choose low rpm quiet fans. And or add reduction cables with resistors built in.
Postby cavorite » 02 Nov 2018, 16:16
What size and thickness will fit? Replace front and back or disable front? Assuming it’s PWM (3 wire).
cavorite
Postby Burgerman » 02 Nov 2018, 21:03
If you disconnect the front you need a resistor on a cable to plug in as A poster here tried no fan. I tried it too, but no failure to start, but I had it started already, and a resistor cable intended for a computer plugged in, so maybe a different scenario. From memory its using only 2 wires.
There are thick and thin fans. The rear one can be replaced with a thicker one, the front can JUST in the fancy case, but dont know about the stock case. So get 2x 80mm fans. Get low power low RPM ones. The rear can be thicker at least in the fancy case. Not sure about the original rack case. So get 2 thin ones.
Postby Gnomatic » 02 Nov 2018, 21:06
I believe the sock fans are 80mm square by 15mm thick. If you put the fancy case on it, you can fit 25mm fans in there.
Postby cavorite » 03 Nov 2018, 01:25
The selection of 15mm fans is underwhelming. I sure wish a 25mm would fit in stock enclosure. Changing to fancy enclosure just to fit thicker fan is probably one step too far for me.
cavorite
Postby Burgerman » 03 Nov 2018, 01:43
At first I didn't think it loud. I can pretty much ignore most fans, sleeping in my room means PC on 24/7 etc. But at low currents, where theres no other sounds at night it is quite loud. Put it under the bed. Dont have any leaks...
Postby Gnomatic » 03 Nov 2018, 22:33
BM that video is nuts! Reminded me of playing Half-Life.
Postby Burgerman » 03 Nov 2018, 23:29
I know. How is it even possible? Those "proper people" explore a lot of other things too in a few countries. They search out weirdness...
Postby Gnomatic » 04 Nov 2018, 01:31
What do you think is the probability they actually calibrated and tested their geiger counter before going in there?
Postby Burgerman » 04 Nov 2018, 07:25
Non, but if there was anything significant it would be obvious. If they had it on. Most of the time they didn't..
The electricity, old cables, metal cabinets, and that buzzing would worry me more. Nuclear stations are generally connected to the grid by some very high voltage lines. And who knows what was actually connected. Notice the hanging orange tapes, used for danger on electricity power lines in various places.
Postby Gnomatic » 04 Nov 2018, 22:47
The good news. My second PSU arrived at my door a week or so after shirley shipped it. (Thank you, shirley! :thumbup: )
The bad news: customs handled my parcel with only the finest of care.
I tested it; seems to work fine despite the above.
Postby Burgerman » 04 Nov 2018, 23:44
They do that here too. So no physical damage?
Postby shirley_hkg » 05 Nov 2018, 00:36
They treated it much worse than taobao. :thumbdown:
Postby Gnomatic » 05 Nov 2018, 01:04
No apparent physical damage, which is fortunate since I could see it through the holes in the box. When they said they were "processing" my package, I guess this is what they meant.
Postby ex-Gooserider » 05 Nov 2018, 23:41
Take lots of pictures, save the box, and test contents - if damage, call the carrier ASAP and file a complaint... As I understand the rules in the US, the last carrier to handle the package is responsible for damage unless they made a note of it when they got the package from the previous carrier...
Postby mickeymonk » 25 Nov 2018, 01:37
shirley_hkg wrote:Another ZXD2400 to UK . cheers
Arrived today, thank you very much Shirley, with a bonus of no customs charges. :mrgreen:
Mick
mickeymonk
Postby shirley_hkg » 08 Feb 2019, 04:39
Someone has taken the last step done .
Now you can buy it with new outfit .
Postby steves1977uk » 08 Feb 2019, 16:41
I might get one or two Shirley :) How much in GBP£'s including shipping?
Postby Burgerman » 08 Feb 2019, 21:06
Just lacking the anderson out to cope with high amps without melting the front connectors... Remember it can do 50A and 60V.
But easy add.
Postby Gnomatic » 09 Feb 2019, 01:04
I would have probably bought this if available at the time. But installing the PSU in the fancy case made for a nice project at least.
Postby Burgerman » 09 Feb 2019, 01:12
I have another still to do. And 2 more BT conversions to fit. And still stuck on bed mostly... And a BM3 to fix. And my ex gf younger sister is coming for 14 days from belgrade, and I have to chat here up too... So much to do.
Users browsing this forum: acid_coke and 122 guests
