shirley_hkg wrote: We usually set Balance Start V at 3.5, so balance starts here and till the end .
Charge is still going with full throttle .
When voltage keep rising and reaches Charge Voltage eg. 3.58V , PL8 will keep no cell beyond this by manipulating the charge current . It leaves the CC stage and enters CV stage now .
Absorption period may vary . It depends .
CV timeout or Terminal current will end the charge , whichever comes first .
Scooterman wrote:LIPOs?
looking at the PL8 user presets, the termination current varies around C/10 and C/20. The latter value for storage.
Whereas we use a starting TC value of C/500 for LIFE.
So why do we terminate lipos at a higher current?
PS: BM I ordered a cheap 2200mAh 3S lipo to play with.
Burgerman wrote:1st of all you need the laptop connected. Dont look at or press anything on the charger... You can, later, but no need.
Load the XLR preset in position 1.
UPLOAD to the charger. Button says UPDATE.
Then check all the supply, firmware, options tabs and be sure correct settings and options choosen.
Then go to cells tab.
Be sure it says ready at the top.
CHOOSE the correct XLR profile from that drop down box.
Press the charge button on screen.
It should charge now. If not, and any errors will be shown. For eg no battery, or reverse polarity means you wired it wrong.
shirley_hkg wrote: Chemistry of Lipo is much more vigorous with very low internal resistance . Charge reaches every part of the cell very easily
terry2 wrote:I went to File\Open preset to 1
I got no update?
I can see in the preset tab at the top "Gel MK XLR PLUG SAFE"
I went to the cells tab and no drop down menu. But it does say "No Data from PowerLab 8" at the top
And in the firmware tab Halfway down it says "Installed PowerLab 8 Firmware is unknown"
But on the PL8 supply window it says V3.3. Do I need to factory reset the PL8?
Now looking at the PL8 software it says at the top "No Data from PowerLab 8"
It's on the right Com port 3 and it says in green Com 3 open.
steves1977uk wrote:The PL8 has to be switched on while you're using the CCS software to operate/update it. Also is the FUIM3 connected properly?
steves1977uk wrote:terry2 wrote:I went to File\Open preset to 1
I got no update?
terry2 wrote:You was right![]()
I had the 3 pin FUIM3the wrong way round
Now it says at the top "waiting to start"
Thanks for the help.
shirley_hkg wrote: Chemistry of Lipo is much more vigorous with very low internal resistance . Charge reaches every part of the cell very easily , so long absorption period is not necessary .
terry2 wrote:I had the 3 pin FUIM3the wrong way round
shirley_hkg wrote: You can adjust the current any time , via buttons on PL8, without stopping the process .
Burgerman wrote:Lipo and lithium ion is not like Life, it doesent have a flat discharge curve. So is easy to charge, and fuel works, etc. One thing. Dont take below 3.5V or it will soon die. Lipos dont like low voltages. They are low resistance too. So charge to 4.200V and they stay there. No long CV needed. And they will exploe or burn if ypou charge higher than that so be careful, dont charge them unattended.
Users browsing this forum: Bubbernator, snaker and 409 guests
