Burgerman wrote:Because 16x 90Ah cells leaves a gap... And room for 8 smaller cells as well.
expresso wrote:i have a hard time figuring how 16 90ah cells fit - i love to see some pictures when done - i have an empty battery tray that 2 MK 24 sit in perfect - from the 646 chair - but i dont think i can even fit 90ah cells in there at 36mm x 173mm size - i look forward to seeing how it fits - maybe i am missing something here -
Third, there isn't much difference in capacity when charged at 3.4V or 4.2 volts. Maybe 3% maximum. So surprisingly you can charge one of these cells at 3.4V and get almost the same capacity as charging at the recommended 3.65V.
Burgerman wrote:Sounds about right.
Burgerman wrote:If you charge at 3.500V CV (or less), you must set the balance to balance only at CV.
Thats means JUST set balance entire charge? to OFF.
shirley_hkg wrote: First charge is gonna be VERY unbalanced .
Set charge volt @3.50V, or fuller cells would be kept at high volt for prolonged period, waiting the weak ones to catch up.![]()
Prepare to balance a cell or two , if they were way behind .![]()
Scooterman wrote:shirley_hkg wrote:
Prepare to balance a cell or two MANUALLY , if they were way behind .![]()
Oh, okay Shirley thanks. And from what BM said earlier, I’ll set balance to off.
Burgerman wrote:Oh, okay Shirley thanks. And from what BM said earlier, I’ll set balance to off.
Thats not what I said...
Burgerman wrote:No idea I use the laptop...
Read the manual.
What do mean by this Shirley? How can I manually balance a cell or two if they're well behind the others?
I'm really looking forward to giving them their first charge this morning, I've got all the temporary links made, I just gotta fit them. Can't wait
shirley_hkg wrote:PL8 is fun .
I'm balancing some newly bought 25h cells ; below 3.5v.
Charge volt set at 3.475V .
Will bring it up at 3.6V afterwards.
Users browsing this forum: Google Adsense [Bot], john66, Potty and 2485 guests
