If you don't know, at the top of the graph you click view, then cell restistance.
Burgerman wrote:If you crimped all those inter cell connections they will be all over the place probably. If not now, in a few months.
Also its normal for 1 and/or 8 to be high, because those cells also have long charge cables added into the measured data.
Scooterman wrote:Terry, when you next charge your pack can you post a picture of the cell resistances, I'm just curious as I've never seen anyone elses.
Burgerman wrote:Also its normal for 1 and/or 8 to be high, because those cells also have long charge cables added into the measured data.
Is it ok to discharge them for an hour or two, then recharge?
Burgerman wrote:Looks OK to me.
Burgerman wrote:You put back 13Ah.
What Amp ws the discharge? Around 4?
How many Ah did you put back after the ride out?
Do you think I should get a fire extinguisher...
Burgerman wrote:Do you think I should get a fire extinguisher...
Always wise. But they dont usually burn unless you hit them with some severe external heat. Anyway if it catches fire and you cant get out then you are likely to poo yourself. If its the right consistency that should put it out.
Went around a few shops.
Burgerman wrote:Yes.Went around a few shops.
That uses as much as your 6 mile spin.
Burgerman wrote:Well you used 21Ah. Out of 176?
Thats 176 div by 21 = 8.3. So you can go 8 times further than that.
So 8x your 6 mile spin and shopping. If you skip the shopping you can likely almost double that.
However, take a look at the inter cell connections. They should all stay relatively close together on that graph.
Burgerman wrote:Also you may notice just 1 hour charge. You can knock 15 mins off that if you increase 30A to 40A charge.
Users browsing this forum: No registered users and 143 guests
