Scooterman wrote:Is the discharge curve steeper than just lithium because it's a discharge curve for a combined lead & lithium pack?
terry2 wrote:expresso wrote:i re done the wiring with cables instead of the copper buss bars - what i found was - 3 loose connections - they were a starting to be stripped so i used a longer screw on those 3 with a lockwasher to thicken it and it tighten down nice now - the rest i didnt use lock washers and shorter screws - all tight - its charging now - so far so good - as long as they stay this way -
also changed the fuse to 100A - this is the 80ah ADD ON for the bounder -
Do you find it better to make long cables than short ones?
Is there any advantage?
Any better than buss bars?
Mine take the shortest route.
Scooterman wrote:Nice on expresso, neat job.![]()
You don't want short straight links Terry, they need to be loke expresso's . So if cells move slightly when hitting bump is doesn't loosen the or strain the terminal connections.
On vibrating machinery you never terminate with straight cable, you always put a helix in the cable.
shirley_hkg wrote: You seem happy !![]()
Burgerman wrote:Yes cells have resistance so loading them up to drive a scooter warms them a few degrees. Lithium cell resistance reduces, nd voltage drop under load follows on so reduces less. And warming the pack increases voltage slightly.
Nw you know why C rate and resistance matters!
Are you wearing out faster than the battery yet?
But it's great that the 1-day range of the scooter far exceeds my physical endurance. I reckon my endurance and concentration could manage 60 miles at a push (4hrs AM, 4hrs PM) on a warm sunny day, but that would be an exception. And the lithium range exceeds that.shirley_hkg wrote: That is one big single lithium battery , meant for INVACARE ARROW's G24 compartment .
CCS stopped responding at the 8th hour , so you only see the last 4 hrs of the discharge .
expresso wrote:i may end up using those grub screws down the line if i have more issues - i would locktite them in there first -
Clearly that device is unsuitable, but I do wish someone could find a cell balancing board that would: (1) start balance only near or at the end of CV, (2) dissipate or exchange enough current to balance reasonably quickly (would 3A be enough?).
Dogsbody wrote:
Don’t think this is a BMS, but balancing circuits... any chance you could take a look for an opinion?
Also Shirley can you help me with A TaoBao purchase please?
Dog
Burgerman wrote:Depends how much.
Users browsing this forum: acid_coke, shirley_hkg and 109 guests
