expresso wrote:more
Burgerman wrote:No its to see how much you take out!
If you charge to a safe 3.600V, discharge to a safe 2.90V then you are measuring around 95% to 97% of the cells ACTUAL capacity.
Rather than the claimed capacity which can be because the chinese exadurate, or because the cells are wearing out or damaged by under or over charge/discharge in volts or Amps.
terry2 wrote:
I am trying to run mine down by going out and about.
But it's going to take ages until the warm weather comes.
I may use the PL8 if it's safe to do so.
[/url]
Burgerman wrote:https://www.rj-lithium.com/sale-11546469-lifepo4-3-2-lifep04-battery-3-2-volt-battery-lifepo4-battery-cells.html
the 92Ah ones here seem to be them.
Burgerman wrote:Get a good motorcycle helmet. Warm, quiet, and less likely to be killed so badly. And scare a few old ladies and car drivers...
. Maybe I should glue some split rubber hose along the top edge?
Scooterman wrote:Burgerman wrote:Get a good motorcycle helmet. Warm, quiet, and less likely to be killed so badly. And scare a few old ladies and car drivers...
Hmmm thank you, I think? And may the force be with you BM.
Btw I was going to ask you being an ex-motorcyle man how high to position the top of the screen. But I did some googling and the consensus seems to be just below eye level. So I've decided I'll have a go, I'm quite looking forward to fitting oneI hope it doesn't blow-off when going down the road or decapitiate me if I crash
Burgerman wrote:Bin.
. Mine are filthy and cut to pieces
. What you linked to looks perfect!!!
. Return to Everything Powerchair
Users browsing this forum: emilevirus, Jay_x, sergey0 and 82 guests
