Postby expresso » 09 Apr 2019, 01:22
before
Postby terry2 » 09 Apr 2019, 07:59
expresso wrote:after making wire cables for my 80ah pack - the charge graphs are perfect - cant get any better - they were not bad before -
one pic is before - the perfect line is today after - i now know what to do if it happens again - since i added lock washers to the only 4 that were a bit stripped with larger screw - if i have to redo it again - i will add all lock washers with a touch of locktite and all get larger 10mm screws - change the one wire cable thats not bent - and that should be it -
very happy with these 80ah Cells so far
That looks spot on.
My cables are not right. But trying to find what I am doing wrong is a head banger.
I have made new cables 4 times now :(
Scooterman wrote:You've got nice hands Terry :admirer . Mine are filthy and cut to pieces hanged
Thank you Woody, but I saw your post too late banghead . What you linked to looks perfect!!! cheers .
I ordered this https://www.ebay.co.uk/itm/1-mm-A4-Lexa ... 2749.l2649 this morning. I'll give it a go, but if it doesn't work I won't have lost much and will order that screen.
My sister makes me use those surgical rubber gloves. :D
Burgerman wrote:How flexible? Like a cable?
Yes. The middle part that is covered up can twist\bend\up\down. I may try them when I have nothing to do.
Postby Scooterman » 09 Apr 2019, 08:37
Smashing graph expresso :worship
Postby terry2 » 09 Apr 2019, 11:50
Place your bets!
I know BM will have a field day with me for doing this. BUT :D
I have stripped and rebuilt my pack using the bars\connectors I was sent from china(he does not want them back)
I am now going to charge the pack. Will be better or worse?
I will post a graph after.
Place your bets :D czy
Postby Scooterman » 09 Apr 2019, 12:54
Fingers crossed for you Terry :thumbup:
I really hope you get a good graph, I'm hopefully confident for you. Hard work deserves reward.
If you remember can you also post the resistance graph as well
Postby LROBBINS » 09 Apr 2019, 12:55
Terri,
at least they are tinned so you shouldn't have any problem with copper oxidation
Postby shirley_hkg » 09 Apr 2019, 13:14
I'd open up shrink tube to see one inside.
Postby terry2 » 09 Apr 2019, 13:35
shirley_hkg wrote: I'd open up shrink tube to see one inside.
I did and it's the copper plated strips a tiny bit lose so they can bend.
LROBBINS wrote:Terri,
Thanks dude.
Scooterman wrote:Fingers crossed for you Terry :thumbup:
Graphs posted.
About the same results. So I will take it that those 2 cells are different from the rest.
Postby terry2 » 09 Apr 2019, 13:38
Postby Scooterman » 09 Apr 2019, 14:00
Internal Resistance is really low Terry, that's great :thumbup:
I don't know why them two cells shot high first, BM will know (and Shirley will know too).
I wonder whether it's because:
a) they are weaker cells and have higher resistance so voltage shot high first, although IR looks great :problem: .
b) they are stronger cells and discharged less so became full soonest.
BM will be able to answer, I'm interested :geek:
Postby terry2 » 09 Apr 2019, 14:27
Scooterman wrote:Internal Resistance is really low Terry, that's great :thumbup:
Glad you said the "Internal Resistance " is ok. As I haven't got a clue what it is czy
I think I may discharge the pack to 2.90 on one cell.
BM says as long as it doesn't get and worse. I will be ok.
Postby Scooterman » 09 Apr 2019, 14:42
Your IR is the lowest I've seen, it's fan dabby dozy :dance
The lower IR the better :thumbup:
Re discharge to 2.9v. It will take a couple of days terry, and if you don't like fan noise do it in a room you don't sit in.
Postby shirley_hkg » 09 Apr 2019, 14:49
Experience tells the weaker cells rise sooner . The IR seems too good to be true to me also . PL8 is not good at this.
Switch to MONITOR as soon as recharge ended , to log the voltage drop and graph it for an hour or two .
Discharge the entire pack as one to 2.95V to find out . You will be well rewarded.
Postby terry2 » 09 Apr 2019, 15:01
Well at least I have one thing right :D
shirley_hkg wrote: Experience tells the weaker cells rise sooner . The IR seems too good to be true to me also . PL8 is not good at this.
I will do that now.
Thank you all for your help.
Postby Burgerman » 09 Apr 2019, 16:08
Imagine 'someone', say 'a manufacturer' just for a laugh, came up with a modular design that lets you add the motors & wheels, casters, seat and armrests to the battery box that suits your needs best, with that battery box being the structural base frame.
You'd transplant the parts to a new battery box with more cells as you grow (kids could even start with less ah I assume) or as your budget or mobility needs change...
It's basically the BM design without the tubular frame but with the casters and seat to be attached to the battery box as well.
You can choose a layout based on your budget, your size, your activity... anything really.
Modular...
Runs away screaming! The exact opposite of whats required :cussing
Postby expresso » 09 Apr 2019, 16:09
thanks Scooterman - Terry - time will tell if my pack lasts and dosnt change - if it does - i know what it is and will fix it better -
Terry worse case your Cells are just a bit different - but as long as you can use your Chair all day and not worry - and recharges fine etc,
its a hit and miss with these Cells - now unless you want to really rip the pack apart and test each cell - then rebuild - better connections etc,
thats alot of work - may not be needed at all - follow what BM and Shirley suggest - they usually correct :thumbup:
Postby terry2 » 09 Apr 2019, 17:02
expresso wrote:thanks Scooterman - Terry - time will tell if my pack lasts and dosnt change - if it does - i know what it is and will fix it better -
Yes you are right.
Here is the graph from monitoring. Any thing stick out?
Postby Scooterman » 09 Apr 2019, 17:30
terry2 wrote:Here is the graph from monitoring. Any thing stick out?
Nope, not as far as I can see czy
Are you going to do a deeeeeeeeeeeep discharge?
Postby terry2 » 09 Apr 2019, 17:37
Yes I am.
I won't leave it on over night though.
Postby shirley_hkg » 10 Apr 2019, 00:35
It is safe to run overnight , at least in discharge wise .
Postby terry2 » 10 Apr 2019, 03:54
shirley_hkg wrote: It is safe to run overnight , at least in discharge wise .
I have left it discharging :)
11 hours so far. The cells are at 3.308V and 39000mAH have been taken out.
Good job I am not going out this week :D
Postby terry2 » 10 Apr 2019, 13:12
Just an update
It's been discharging for 19Hrs and 55 mins. OUT=72513 Cells are 3.272
A long way to go yet :lol:
Postby Scooterman » 10 Apr 2019, 14:49
terry2 wrote:Just an update
Sometime tomorrow late afternoon I would guess?
Is the fan noise getting on your nerves yet? :cussing
Postby terry2 » 10 Apr 2019, 15:02
I just turned off my hearing aids :lol:
I have lifted the four corners of the PL8 to let the air blow out and about.
Postby Scooterman » 10 Apr 2019, 15:12
Yes you can’t have too much ventilation terry, as the vicar said to the actress (not sure that works :eh:)
Postby terry2 » 11 Apr 2019, 05:30
I am a bit worried about the discharge.(see picture below)
It's still at 3.22V with 131990 mAH taken out. Should I stop it?
Postby Scooterman » 11 Apr 2019, 07:30
No, nothing wrong with that Terry, keep going
Postby terry2 » 11 Apr 2019, 07:50
Scooterman wrote:No, nothing wrong with that Terry, keep going
Thanks dude.
140 AH out now, and still at 3.207V. I will be glad when it's done :)
Postby Burgerman » 11 Apr 2019, 10:04
You will know when its done. If you are using a preset I sent you, it should stop when the lowest cell drops to 2.90V and they will start to fall suddenly. THEN read the capacity, and you will know how much Ah you REALLY have. And which cell is the smallest capacity. The one that drops first.
Just go to the presets, discharge tab, check that it is set to 2.900V per cell. You cant change it without stopping discharge though... So dont.
Postby terry2 » 11 Apr 2019, 10:52
Burgerman wrote:You will know when its done. If you are using a preset I sent you, it should stop when the lowest cell drops to 2.90V and they will start to fall suddenly. THEN read the capacity, and you will know how much Ah you REALLY have. And which cell is the smallest capacity. The one that drops first.
Thanks BM
I always use your profile.
It does say Discharge Voltage 2.90V
So I will leave it and take pics when it stops.
1 day 17 hours Cap out 152977 mAH and the cells read 3.179V. I hope it reaches 160AH
Users browsing this forum: acid_coke, emilevirus, LROBBINS and 153 guests
