Burgerman wrote:Correct NYLOC nuts. Not NYLON nuts!!!
matter of fact - i had a new
yesterday i never had - not too bad -
will bed stud down nice and snug terry2 wrote:I have got everything now to tackle the stripped thread and studs\ gluing the studs in.
I think I will wait till I need to.
Gnomatic wrote:terry2 wrote:I have got everything now to tackle the stripped thread and studs\ gluing the studs in.
Good luck terry. I'm curious to know which length of grub screws is optimal for your cells.
Burgerman wrote:I am using a bottle of 2700 and it replaced my 270... Not sure what the difference is.
I'm going to use the buss bars which are 2mm thick.
Burgerman wrote:I'm going to use the buss bars which are 2mm thick.
No. Big mistake. Too rigid, and they will not make good contact for long as they will lever against each other and not sit flat enough, and with movement as you drive off a curb, or due to heat/cold will loosen.
Use ring terminals and cable.
Threadlocker Disassembly Removable,
Users browsing this forum: acid_coke, shirley_hkg, Superchunk and 1110 guests
