Programming leads
Re: Programming leads
Postby woodygb » 17 Sep 2018, 10:43
Your P.M.'s went thru fine....I just wasn't around to reply to them.
Postby calabash » 21 Sep 2018, 16:59
A big thank you woody, worked like a dream and now it drives........
calabash
Postby woodygb » 21 Sep 2018, 17:14
Your welcome.
Postby dieseldog » 08 Apr 2019, 16:33
Do we have any knowledge of someone who can supply the rnet dongles yet :) have had a cable of you woody for a few years now but converting the chair to r net.
dieseldog
Postby woodygb » 08 Apr 2019, 16:48
Nope ...you need to purchase a genuine one.
Postby Smitty62 » 20 Apr 2019, 04:24
Woodygb,i am interested in purchasing a programming cable for my jazzy 1100 with a pg-drive pilot-d49637 70amp controller
can you build one for me? if so can pay with paypal
let me know total cost with shipping to;
HC1 Box304h
Fairdealing MO. zip code: 63939 USA
This is a physical home address, not a po. box
Much appreciated, Michael Smith
Smitty62
Postby woodygb » 20 Apr 2019, 10:31
Hi Michael,
Whilst I can supply a lead for the OLD Pilot , the software that is available will not program it.....the software will simply say "Pilot" on the very bottom line of the screen but gives no programming options.
Personally I would swap it out for a later VSi.
Cheers Woody
Postby Smitty62 » 20 Apr 2019, 14:46
Thank you.
I will locate one
Smitty62
Postby Dan » 10 May 2019, 16:36
Woody are you selling the bluetooth boards for the PL8 charger?
Dan
Postby Burgerman » 10 May 2019, 17:56
He sold me mine.
Watch the vid of it in action while doing a quick vid yesterday.
I actually got 3. Only one fitted so far, but will get to it soon. Works like a charm. Cant manage without now as its just easy and seamless.
Laptop on bed in bedroom monitoring, and controlling. Powerchair (salsa) in the kitchen. Typical example of BT as I use it regularly testing batts or charging spare backup chairs etc. As here.
http://www.wheelchairdriver.com/gopro/current-state.mp4
Postby woodygb » 10 May 2019, 18:15
Dan wrote:Woody are you selling the bluetooth boards for the PL8 charger?
I can supply a board programmed to suit with the correct diode and some leads ... NOTE :- It's not plug and play so you will need to fit it internally / externally to the PL8.
Postby expresso » 10 May 2019, 19:26
Hi Woody - i may be interesting in one also - may give it a try - would you have or can supply instructions on how to do it - internally and externally ? pictures would be excellent :D
Postby Burgerman » 10 May 2019, 19:32
When I do the next one, I will do a set of pics and instructions. But really, its easy. And kind of self explanitory.
The low drop diode, is essential though. The simple signal diode works only if you dont charge at high power.
A couple of simple filter caps, may or may not be needed. I fitted them anyway. And its a bomb proof setup. Just works.
Once you do it, messing about having to plug it into a computer and being limited to length of USB wire etc is all a pain and not needed. You cant go back!
Postby expresso » 10 May 2019, 19:38
Ok i will be on the look out for your Pics and step by step - Will purchase from Woody and follow your instructions - if all goes well - i will do my others also - i run a few Pl8s at a time during the summer high usage and have wires all over the place - it works - but would be nice without that one wire also
now this can also be used with the Cable down the line if needed once its done wireless ?
Postby woodygb » 10 May 2019, 19:48
IF your having more than one remind me to program them as PL8A ,B ,C etc... or some identifying word/s to help distinguish between each..
Postby Burgerman » 10 May 2019, 19:49
Yes. The way mine are done leaves a 3 pin connector hanging out of the rear, plugged into the same place the FUIM3 normally fits. So you just unplug that, and connect the FUIM3 instead.
But I dont think you will ever need do that. Maybe only for secure firmware updates. I would probably risk the BT though...
Postby expresso » 10 May 2019, 21:27
woodygb wrote:IF your having more than one remind me to program them as PL8A ,B ,C etc... or some identifying word/s to help distinguish between each..
yes very good thanks - i will PM you in a while about it etc,
Postby Burgerman » 11 May 2019, 06:39
Warning. Not sure that the last 2 you programmed are working. Very fast test yesterday. The name change may make them not work... Spaces? More than 8 letters? Or it may have been something else. Will test them again soon.
Postby Mkay » 17 Jul 2019, 12:25
Hello woody, I just wanted to let you know I have dropped you an NG email ordering a lead to the orange address. Incase its not one you monitor. Cheers
Mkay
Postby woodygb » 17 Jul 2019, 17:02
Mkay wrote:Hello woody, I just wanted to let you know I have dropped you an NG email ordering a lead to the orange address. Incase its not one you monitor. Cheers
The orange email is DEAD...has been for a few years.
use nala_doow ( at) hotmail (dot) com
Postby Porkchops » 22 Aug 2019, 21:18
Hi would anyone be able to make a curtis 1314-4401 cable or know where to get one at a decent price
Porkchops
Postby woodygb » 22 Aug 2019, 21:48
Yes...All you need is a TTL-232R-3V3-WE and a little reprogramming via the FT_Prog utility.
https://www.ftdichip.com/Products/Cable ... Serial.htm
https://www.ftdichip.com/Support/Utilities.htm#FT_PROG
Postby Porkchops » 23 Aug 2019, 13:42
Or if possible I was wondering if you make any of them and if so I'll be happy to purchase one from you
Porkchops
Postby woodygb » 23 Aug 2019, 16:21
I will happily make one for you ...what are you trying to connect to?
Postby Porkchops » 23 Aug 2019, 17:26
I want to connect to a scooter controller a 1212 I believe it is
Porkchops
Postby Porkchops » 23 Aug 2019, 17:30
On second thoughts I'd like to try and make a cable first if I have any problems I'd get you to do me one if that's ok.
Is the cable I've linked ok to order ?
Dont mean to mess you around
Porkchops
Postby woodygb » 23 Aug 2019, 17:59
Yes ...that cable is fine ..you'll also need a mini molex.
I usually use something like this as the donor for the molex.
https://www.ebay.co.uk/p/4-Pin-Molex-to ... 0888&rt=nc
FTPProg is used to INVERT the RX and TX signals..
Postby Porkchops » 23 Aug 2019, 18:15
Ok sounds good going to order that now. Is there some sort of guide to program the cable and also a link to the appropriate software?
Porkchops
Postby woodygb » 23 Aug 2019, 18:20
http://www.nocoev.com/curtis/Software%201314-4401/
Guide ...Ummm not really ...run FTProg and INVERT the RX and TX.
Users browsing this forum: No registered users and 36 guests
