Ottobock might sort their marketing out eventually and realise they need to provide accurate information.
Order form pdf is too big to upload
Burgerman wrote:Otto bock baffle me.
I wanted to look at specs and tech details to see if a single centre footrest, was an option, and if they had grp24 batts/4 pole/6mph/rnet 120 options. And a price. Their website seems to want to tell you nothing useful and send you off to a useless dealer. So I cant buy one!![]()
https://www.ottobock.co.uk/wheelchairs- ... eelchairs/
Where are all the details, options, prescription forms, tech info, prices, with various configs, etc. How can I even consider if its suitable if I cant find anything out about them?
Burgerman wrote:Excellent work!
Not exactly cheap.
So no 120A R-net. No idea if 2 or 4 pole motors so likely 2. And no grp24 batteries... So non of the basic essential starting point essential options.
Burgerman wrote:If the programmer works yours MUST be R-net. Rebranded? Do not know.
TEN°
The TEN° handheld control device constitutes a small ergonomic revolution providing secure positioning and prevents fatigue. The high resolution 3.5” colour display features modern and easy to understand imagery. Additionally, the innovative rotary dial with a 10° rotation angle permits fast regulation of the speed whilst the housing is extremely robust and available in various colours.
wheelie junkie wrote:I need to get a support worker to look under the seat, if it is their own system what else would be R Net? It has Omni and a Mo Vis joystick but can be programmed with R Net dongle and software. Confused?? Or have they just rebranded R Net?
Burgerman wrote:Yes. In order of cost,there is 2 channel, 4, 6 and a mythical 8. All do lights as well. But you dont have to use any, or just one. Or just lights. And its a bus cable. You can connect any amount of modules and joysticks in any order you want.
expresso wrote:i see - so its safe to purchase items that came off a permobile chair - can you get rid of the logo perobile when it turns on JS - i seen some that way - i asked a seller about if it would work - he said it may work it came off a permobile or may not work with quickie -
-i though the same thing as you just said - i always save the original file and have a dozen of files saved settings etc, - so any PM Rnet OEM 120A would work - and that ISM 6 you got - my chair has seat lift and tilt - i never looked at that box that controls that stuff - its inside hidden
that ISM 6 would work for me to control the seat lift and tilt also - if i had to change it - just unplug same cables etc, - add my file - programmed and thats it ? if it ends up in the same chair etc, that would be it plug and play ?
Users browsing this forum: LROBBINS and 472 guests
