Scooterman wrote:How is your Lithium pack going Terry? Have you redone the dodgy thread with a helicoil? Sorry if you’ve already said, I’m on my phone and it’s a bit small for reading back through thread, need a bigger phone
Burgerman wrote:I am using a bottle of 2700 and it replaced my 270... Not sure what the difference is.
Burgerman wrote:But nobody listens.
Scooterman wrote:Burgerman wrote:But nobody listens.
I do BM![]()
I was too cheap to buy locktite so used some superglue from Poundland. It's really good value, 3 bottles for a pound
Burgerman wrote:Everything metal that I ever used superglue on corrodes like hell. All rusty and brown and never comes apart. So it may work better than intended.
. I have to use post image as my mac takes an age to resize images when running OS X. Not enough RAM me thinks Burgerman wrote:Nothing wrong there.
biscuit wrote:I'm struggling with my new 40Ah prismatic cells. Their terminals are M10 studs.
Burgerman wrote:You need ring terminals with a 8mm hole. And 6mm2 cable entry.
And 8mm hole with whatever sqmm the balance wires are...
shirley_hkg wrote:Cool connector. What's it called ?
Burgerman wrote:Dunno. But its huge! Unless thats a photo trick.
Burgerman wrote:No you need a amall phone for calls. And a PC for computering.
, then for that as well. And a phone for everything else. Btw Burgerman if you're using word for your text and your caps lock sticks, iirc you highlight the offending text and press shift+F3 to cycle through the cases.Scooterman wrote:Was it a d-sub connector? I have one spare if you need one, I bought more than I needed off Shirley.
, till the last Ah.
Users browsing this forum: acid_coke, duke1, jefferso, LROBBINS and 356 guests
