shirley_hkg wrote:Only 1 mV , while discharged to the last 0.1 . . . . amphere hour.
Scooterman wrote:
Is it not 4.2v for all non-lifepo4 lithium cells?
Okay I have this battery pack. To be fair it was sat around for 2 with 3 years before it was fitted. And because I wanted to experiment to make it easier for ordinary people to use the wheelchair, I fitted a balancer. However for whatever reason this has not been successful.
Out of this current battery pack on this wheelchair I am only getting about 6 miles, and then it just stops dead.
Secondly, it has developed a problem recently, of when you put the charger on it only gives you the option of "one cell". This battery pack when it is charging normally has 8 cells. I messed about with it the other day and it worked, providing 8 cells charging again, and today I had to take it out of the wheelchair before it would do 8 cells charging again.
So in the long run I would like to build a new battery pack, so was the webpage created explaining in detail how to make a 24 V battery pack to fit the BM 2 battery box specifications?
I'm a tetraplegic and the guy who is doing it for me as a tiny bit more electrical knowledge than I do. So we need a "for dummies"
foghornleghorn wrote:Have a 4 digit voltmeter
foghornleghorn wrote:Range testing my pack on the same route I used testing the lead batteries previously going out and doing 2 hours, home for rest, then continuing.
Have a 4 digit voltmeter wired in which was there whilst PL8 was discharge testing before pack fitted to wheelchair, so confident it is accurate enough to believe. Been looking at voltage while pausing at the mile markers, also been checking the voltage drop regularly while moving.
Got to the point now where stationary voltage is 26.02, driving along at a very sight incline (69ft height increase over a mile) it drops to 25.75, and driving up the hill to my house (10 degrees) it drops to 25.08 then bounces up again once stopped.
In terms of when to give up the test and call it far enough is it the voltage when I stop that I should concentrate on, or under load?
Scooterman wrote:Can you see the voltmeter display while driving along? Where have you mounted it?
foghornleghorn wrote:On the end of a long snake that is tucked under my knee or up in my hand for looking at. Not found anywhere to permanently fix it that is easy to view.
Scooterman wrote:BM - In emergency tavel situations away from home when charging on the fly. Would a couple of bulk charges without balance phase unbalance a pack too much? I think my pack would probably be okay but that's just a guess...
Maybe the same one who keeps trying to make InstallShield Pro (a VERY expensive Microsoft product) compatible with the ever changing Windows OS ways of doing things. Or the one responsible for its 5,000 page un-organized manual.PL8 software was not well designed, it seems written by an unskilled student.
Gnomatic wrote:That's the CCS screenshot right after I disconnected the charger in the morning.
steves1977uk wrote:Gnomatic wrote:That's the CCS screenshot right after I disconnected the charger in the morning.
Once the charge is complete, the charger monitors the cells and cell voltages drop very slowly until the STOP button is clicked. Maybe a bad/dirty connection somewhere Gnomatic?
Users browsing this forum: No registered users and 295 guests
