Obviously I would prefer to order via a dealer recommended by a forum member, but price is a priority for me. I don't care if the cells have been used previously as long as they have a decent amount of life left in them (how do you tell?).
greybeard wrote:I need some help guys.
My wife just had a spell in hospital and this has made me realise that many of the day to day things I should have been able to manage for myself have become impossible because the chair has lacked the range needed. I need to make an add on pack.
Problems:
I only have dumb 8amp chargers. The charging method needs to be via XLR socket.
I lack the funds for a power supply.
I lack the funds for a PL8.
I am 76 years old and have difficulty understanding and retaining the build information in the lithium build threads even though I read them religiously.
My hands shake too much for reliable soldering, not helped by lacking acute vision in one eye (no parallax for judging distances)
I would be grateful if you could all give me the benefit of your expertise and advise me the best way forward, eg what batteries would be best to give me a usable extra 30 or 40AH over my grp 34 batteries? (grp 24 will not fit in either of my chairs). What is the best place to order them from?
I understand that I will have to incorporate a BMS because of the only charging method open to me. At my age the shorter battery life is not a significant problem.
Shirley has kindly offered to source all the other parts required.
Thanks in advance.
greybeard wrote:To avoid any confusion, below is my original post from the Expresso's 30ah addon thread. Please post any advice etc in this (60ah) thread. Thanks.greybeard wrote:I need some help guys.
Problems:
Thanks in advance.
flagman1776 wrote:
Here's the problem... one 8ah charger working through the XLR socket isn't enough to charge an add-on AND your in-chair lead batteries during an overnight charging if left connected. It's just not enough output. You could separate the add-on from the chair electrically... unplug one Anderson SB50 plug... and use a second charger to charge the add-on. Do you have enough hand strength to do this? Maybe someone can think of another way to disconnect the 2 batteries.
flagman1776 wrote:The only real answer is a faster charger.
I'll send him a small 3.65V power module , powered from chair's lead bricks , to do individual cell balance safely .![]()
Yes. 45 is ok, provided you could find good stuff .
Dan wrote:@greybeard What is your budget?
Burgerman wrote:Its all a matter of luck. In reliability, seller, quality, etc. Unless you buy from shirley who can see whay you are getting, test a cell etc.
Users browsing this forum: emilevirus, Juggler258, Seafighter, Superchunk and 523 guests
